Learn how to automate the integration of Wix Forms with Riggy using Pabbly Connect. Follow our detailed tutorial for seamless automation. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Setting Up Pabbly Connect for Wix Forms and Riggy Integration
To begin the integration process using Pabbly Connect, first create an account on the platform. This is essential for automating the workflow between Wix Forms and Riggy. After signing up, log into your Pabbly Connect dashboard and click on the ‘Create Workflow’ button.
Next, name your workflow (e.g., ‘Wix Form to Riggy’) and select the appropriate folder for organization. Click on ‘Create’ to proceed. This initiates the workflow setup, where you will define triggers and actions to automate the data transfer between Wix Forms and Riggy.
2. Setting Up the Trigger with Wix Forms in Pabbly Connect
The next step involves setting up the trigger in Pabbly Connect. In the trigger window, search for ‘Wix Forms’ and select it. In the trigger event dropdown, choose ‘New Form Submission’. This configuration ensures that every time a new form is submitted, it will trigger the workflow.
- Search for ‘Wix Forms’ in the app selection.
- Choose the trigger event as ‘New Form Submission’.
- Copy the generated webhook URL provided by Pabbly Connect.
After copying the webhook URL, navigate to your Wix site editor. In the left sidebar, go to the ‘Automation’ section, click on ‘New Automation’, and select ‘Start from Scratch’. Choose ‘Wix Forms’ as the trigger and select the specific form you wish to connect. Finally, paste the webhook URL in the action step and activate the automation.
3. Configuring the Action to Add Users to Riggy
After setting up the trigger, the next step is to configure the action in Pabbly Connect. In the action window, search for ‘Riggy’ and select it. Choose the action event as ‘Import User’. This will allow you to add users to your Riggy account based on form submissions from Wix.
To connect your Riggy account, you will need to enter the API token from your Riggy account. Navigate to the ‘Integrations’ section in Riggy, select ‘P API’, and copy the API key. Paste this key into the connection window in Pabbly Connect and click on ‘Save’.
- Select the action event as ‘Import User’ in Riggy.
- Enter the API token from your Riggy account.
- Map the user details from the Wix form submission to the action fields.
Ensure you map the full name, email address, and phone number correctly from the trigger responses to the action fields. This mapping process is crucial for transferring the correct user information to Riggy.
4. Testing the Integration Between Wix Forms and Riggy
With the integration set up, it’s time to test the automation using Pabbly Connect. Submit a test entry through your Wix form. This step should trigger the workflow, sending the data to Riggy automatically. After submission, check your Pabbly Connect dashboard to see if the webhook response has been captured.
Once the response is received, verify the user has been added to your Riggy account. You can do this by navigating to the user management section in Riggy. Search for the user you just submitted via the Wix form to confirm the integration is functioning correctly.
5. Conclusion: Streamlining Your Workflow with Pabbly Connect
In conclusion, using Pabbly Connect to integrate Wix Forms with Riggy significantly streamlines your workflow. By automating the process, you ensure that every new form submission is instantly reflected in your Riggy account, saving you time and effort.
With this tutorial, you have learned how to set up the integration step-by-step. This automation not only enhances efficiency but also improves user experience by ensuring timely enrollment in your courses. Start utilizing Pabbly Connect today to automate your workflows effectively!
