Learn how to send WhatsApp messages to new Facebook leads using Pabbly Connect in this detailed tutorial. Follow the steps for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin using Pabbly Connect, first access the dashboard by signing up through the free link provided. This is your starting point for integrating WhatsApp with Facebook leads.
After signing up, navigate to the dashboard and click on ‘Create Workflow’. Name your workflow, for example, ‘Facebook Leads to WhatsApp’, and then click on the ‘Create’ button to set up your integration.
2. Configuring Facebook Lead Ads in Pabbly Connect
In Pabbly Connect, the next step is to set up the trigger for your workflow. In the trigger window, search for ‘Facebook Lead Ads’ and select it.
- Choose ‘New Lead’ as the trigger event.
- Click on ‘Connect’ and select ‘Add New Connection’.
- Connect your Facebook account by clicking the ‘Connect with Lead Ads’ button.
Once connected, select the Facebook page where your lead ads are running. Choose the lead generation form from which you want to capture new leads and click on ‘Save and Send Test Request’.
3. Sending WhatsApp Messages to New Leads
Now that you have set up the trigger, it’s time to configure the action in Pabbly Connect. In the action window, search for ‘Double Tick’ and select it.
- Choose ‘Send WhatsApp Template Message’ as the action event.
- Click on ‘Connect’ and add a new connection using your Double Tick API key.
- Map the WhatsApp number from the lead details captured in the previous step.
After mapping the phone number, select the template you want to use for the WhatsApp message from your Double Tick account. Ensure that the template has been approved by Facebook.
4. Testing Your Integration with Pabbly Connect
With the setup complete, it’s time to test your integration in Pabbly Connect. Generate a test lead using the Facebook Lead Ads testing tool to see if the WhatsApp message is sent successfully.
Once you submit the test lead, check the WhatsApp account associated with the number you used. You should receive the template message confirming the lead registration.
This process verifies that your automation is functioning correctly, allowing you to send WhatsApp messages to new leads generated from Facebook.
5. Conclusion: Automate Your Lead Nurturing with Pabbly Connect
In conclusion, using Pabbly Connect to integrate WhatsApp with Facebook Lead Ads streamlines your lead nurturing process. By following these steps, you can automate communication with new leads effectively.
This integration not only saves time but also ensures that your leads receive timely messages, enhancing your engagement strategy. Start using Pabbly Connect today to automate your workflows seamlessly.
