Learn how to automate WhatsApp messages to your Facebook leads for your construction business using Pabbly Connect. Step-by-step tutorial included. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To send WhatsApp messages to your Facebook leads for your construction business, you first need to access Pabbly Connect. This powerful automation software allows you to set up workflows that connect various applications seamlessly. Start by visiting the Pabbly Connect landing page.
Once there, you will see options for signing in or signing up. If you are a new user, click on ‘Sign up free’ to create an account. Existing users can simply click ‘Sign in’ to access their dashboard. This dashboard is where you will create your workflow for sending WhatsApp messages automatically.
After signing in, you will land on the Pabbly Connect dashboard. Here, you can start creating your workflow by clicking on the ‘Create Workflow’ button located at the top right corner. A dialog box will prompt you to name your workflow. using Pabbly Connect
  • Name your workflow, e.g., ‘Work Joy Facebook Leads to WhatsApp Message’.
  • Select a folder for better organization.
  • Click ‘Create’ to finalize your workflow setup.
With your workflow created, you will need to set up the trigger and action for your automation. The trigger will be Facebook Lead Ads, and the action will be the WhatsApp Cloud API, enabling you to send messages automatically when a new lead is generated.
3. Setting Up the Trigger with Facebook Lead Ads
In this step, you will configure the trigger in your Pabbly Connect workflow. Select Facebook Lead Ads as your trigger application and choose ‘New Lead’ as the trigger event. This ensures that every time a new lead is generated, Pabbly Connect will capture the response.
To connect your Facebook Lead Ads with Pabbly Connect, click on the ‘Connect’ button. If you haven’t connected your Facebook account yet, choose ‘Add New Connection’ and follow the prompts to authorize your account. After successful authorization, select the appropriate Facebook page and lead form from which you want to capture leads.
4. Configuring the Action with WhatsApp Cloud API
Next, you will set up the action in your workflow. Choose WhatsApp Cloud API as your action application and select ‘Send Template Message’ as the action event. Click on ‘Connect’ and then ‘Add New Connection’ to input the necessary details such as the token, phone number ID, and WhatsApp business account ID. using Pabbly Connect
To retrieve these details, you will need to set up your WhatsApp Cloud API account via Meta for Developers. Once you have your token and IDs, paste them into the respective fields in Pabbly Connect and click ‘Save’. Afterward, select the desired message template that you have created for your WhatsApp messages.
  • Ensure your template includes variables for personalization.
  • Map the phone number and other details from the Facebook lead response.
Finally, test your setup by clicking ‘Save and Send Test Request’. If successful, you will see a message status indicating that the WhatsApp message was accepted, confirming that your integration works as intended.
5. Testing and Finalizing Your Automation
To ensure that your workflow is functioning correctly, you will need to perform a test submission of a new lead. Return to the Meta for Developers platform and use the Lead Ads Testing Tool to submit a new lead. After submitting, check your WhatsApp to confirm receipt of the message.
If you see the WhatsApp message, it means your automation is successfully set up. You can now delete the previous test lead and submit a new one to see if the automation triggers again. This process verifies that every new lead generated through Facebook will receive a WhatsApp message automatically via Pabbly Connect.
In summary, using Pabbly Connect to automate WhatsApp messages to your Facebook leads simplifies communication for your construction business. This integration allows you to nurture leads instantly, enhancing customer engagement and improving your marketing efficiency.
