Learn how to integrate Webflow with Active Campaign and Go High Level using Pabbly Connect for seamless lead management. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start integrating Webflow with Active Campaign and Go High Level, first, access Pabbly Connect. This platform facilitates seamless connections between various applications, making automation easy.
Begin by signing up or logging into your existing account on Pabbly Connect. After logging in, navigate to the dashboard where you can create new workflows. Click on the ‘Create Workflow’ button to initiate the integration process.
In this section, you will create a workflow that captures form submissions from Webflow. This workflow will automatically create contacts in both Active Campaign and Go High Level. using Pabbly Connect
To set up the workflow, follow these steps:
- Click on the ‘Create Workflow’ button in the top right corner.
- Name your workflow, e.g., ‘Create Active Campaign and Go High Level Contact on Webflow Form Submission’.
- Select a folder for your workflow, such as ‘Automations’.
Once you have named your workflow and selected the appropriate folder, click on the ‘Create’ button to finalize the setup.
3. Configuring the Trigger in Pabbly Connect
The next step involves setting up the trigger that will initiate the workflow. In this case, the trigger will be a new form submission from Webflow.
Select Webflow as your trigger application and choose ‘New Form Submission’ as the trigger event. This ensures that every time a form is submitted on your Webflow site, Pabbly Connect captures the data automatically.
After selecting the trigger event, you will receive a webhook URL. Copy this URL and go to your Webflow account to set up the webhook. Under the settings of your Webflow site, navigate to ‘Integrations’ and add a new webhook using the copied URL. Ensure you select ‘Form Submission’ as the trigger type.
4. Setting Up Actions in Pabbly Connect
After configuring the trigger, the next step is to set up actions in Pabbly Connect. This involves creating new contacts in both Active Campaign and Go High Level.
First, select Active Campaign as your action application and choose ‘Create a Contact’ as the action event. You will need to connect your Active Campaign account using the API key and URL from your Active Campaign settings.
Next, map the fields from the trigger to the action. This means linking the data from the form submission to the corresponding fields in Active Campaign, such as email, first name, last name, and phone number. Repeat the process for Go High Level by selecting Lead Connector V2 as the action application and setting up the ‘Create a Contact’ action.
Once all configurations are complete, it’s time to test the integration. Go back to your Webflow site and submit a test form with dummy data.
After submission, check both your Active Campaign and Go High Level accounts to confirm that the new contact has been created successfully. You should see the details populated as per the data submitted.
This testing phase ensures that your workflow is functioning as intended and that Pabbly Connect is effectively linking Webflow with both Active Campaign and Go High Level for streamlined lead management.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Webflow with Active Campaign and Go High Level. By automating the process of creating contacts, you can enhance your lead management and ensure no inquiries slip through the cracks.
