Learn how to integrate Webflow with Bravo using Pabbly Connect. Follow this detailed tutorial for seamless contact creation on form submissions. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To begin integrating Webflow and Bravo, first access Pabbly Connect by typing Pabbly.com/connect in your browser. This powerful tool allows you to automate tasks without any coding skills.
Once on the Pabbly Connect homepage, sign in using the top right corner options. If you are a new user, you can sign up for free, receiving 100 tasks monthly. After signing in, navigate to the Pabbly Connect dashboard to start creating your workflow.
In the Pabbly Connect dashboard, click on the ‘Create Workflow’ button to start your integration process. Name your workflow, for instance, ‘Create Bravo Contact from Webflow Form Submission,’ and select a folder for organization. This is where you’ll set up the connection between Webflow and Bravo. using Pabbly Connect
  • Click on ‘Create Workflow’.
  • Enter your workflow name.
  • Select a folder to save the workflow.
After creating the workflow, you will see two boxes: one for the trigger and one for the action. The trigger will be Webflow, and the action will be Bravo. This setup ensures that whenever a form is submitted in Webflow, a contact is automatically created in Bravo.
3. Setting Up the Trigger in Webflow
To set up the trigger, select Webflow as the trigger application and choose the event ‘New Form Submission’. Pabbly Connect will provide you with a webhook URL that acts as a bridge between Webflow and the integration. using Pabbly Connect
Next, log into your Webflow account, navigate to the project settings, and find the integration tab. In the webhook section, add the provided webhook URL and select ‘Form Submission’ as the trigger type. Ensure you save the settings to establish the connection.
After setting up the webhook in Webflow, it’s crucial to test the integration. Submit a test form in Webflow with dummy data. For example, enter a first name, last name, email, and mobile number, then submit the form.
Return to Pabbly Connect to check if the response from the form submission is captured. If successful, the details will appear in the webhook response section, confirming that Webflow is correctly connected to Pabbly Connect.
5. Creating a Contact in Bravo
Now, set up the action by selecting Bravo as the application and choosing ‘Create or Update Contact’ as the action event. Connect your Bravo account by entering your domain and API key. This connection allows Pabbly Connect to send data from Webflow to Bravo. using Pabbly Connect
Once connected, map the fields from the Webflow response to the corresponding fields in Bravo. For instance, map the email, first name, last name, and phone number. After mapping the fields, click on ‘Save and Send Test Request’ to create the contact in Bravo.
Finally, verify in your Bravo account that the contact has been successfully created. You can check the list where the contact should appear, confirming that the integration works seamlessly.
This tutorial demonstrated how to integrate Webflow and Bravo using Pabbly Connect, allowing for automatic contact creation upon form submission. By following these steps, you can streamline your workflow and enhance your email marketing efforts efficiently.
