Learn how to integrate Viral Loop with Automizy using Pabbly Connect. Follow this step-by-step tutorial for seamless automation. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Viral Loop with Automizy, access Pabbly Connect. This platform serves as a bridge between various applications, enabling seamless data transfer. Navigate to the Pabbly Connect dashboard to begin the setup process.
Once on the dashboard, you can create a new workflow. This workflow will facilitate the connection between Viral Loop and Automizy. Ensure you are logged into your Pabbly account to access all features.
2. Setting Up the Viral Loop Trigger in Pabbly Connect
In this section, you will set up the trigger from Viral Loop using Pabbly Connect. Select Viral Loop as the application from the trigger options. This step is crucial to receive data when a new lead is captured.
  • Choose ‘New Lead’ as the trigger event.
  • Connect your Viral Loop account by authenticating it.
  • Test the trigger to ensure it is working correctly.
After completing these steps, you will be ready to move on to the next part of the integration. This setup allows Pabbly Connect to listen for new leads from Viral Loop and trigger actions in Automizy.
3. Configuring Automizy Action in Pabbly Connect
Next, configure the action that will occur in Automizy when a new lead is received from Viral Loop through Pabbly Connect. Select Automizy from the action application list.
Choose ‘Add Subscriber’ as the action event. This will allow you to add the new lead information directly into your Automizy account. You will need to connect your Automizy account and map the fields from Viral Loop to Automizy.
  • Map the email address field from Viral Loop to Automizy.
  • Include any additional fields you wish to capture, such as name or phone number.
  • Test the action to confirm that data is being sent correctly.
Completing this setup ensures that every new lead captured by Viral Loop is automatically added to your Automizy list, streamlining your marketing efforts.
4. Testing the Integration Between Viral Loop and Automizy
After configuring both the trigger and action in Pabbly Connect, the next step is to test the entire integration. This is crucial to ensure that data flows smoothly between Viral Loop and Automizy.
Perform a test by submitting a new lead through your Viral Loop campaign. Monitor the Pabbly Connect dashboard to see if the lead is captured and added to Automizy. This step verifies that your integration is functioning as intended.
If the test is successful, you will see the lead appear in your Automizy account. If not, revisit the mapping and settings in Pabbly Connect to troubleshoot any issues.
5. Finalizing the Integration Setup
Once the testing is complete and successful, it’s time to finalize the integration setup using Pabbly Connect. Make sure to save your workflow to ensure that it runs automatically in the background.
Additionally, you can set up notifications in Pabbly Connect to alert you whenever a new lead is added. This feature enhances your ability to respond quickly to new subscribers.
With everything set up, you can now enjoy the benefits of automated lead management between Viral Loop and Automizy, allowing you to focus on other important aspects of your marketing strategy.
In this tutorial, you learned how to integrate Viral Loop with Automizy using Pabbly Connect. This integration automates lead management, enhancing your marketing efforts and ensuring no lead is missed. With Pabbly Connect, you can streamline your workflows effectively.
