Learn how to integrate URL and Box using Pabbly Connect. Follow this detailed tutorial for seamless automation between your applications. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To integrate URL and Box, you will first need to access Pabbly Connect. Visit the Pabbly Connect homepage by searching for it in your browser. Once there, you can either sign in if you’re an existing user or click on ‘Sign up free’ to create a new account.
After signing in, you will be directed to the Pabbly Connect dashboard. Here, you can see all available applications. To start your integration, click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
In this step, you will create a new workflow to automate the integration between URL and Box using Pabbly Connect. A dialog box will appear asking you to name your workflow. Enter a descriptive name such as ‘Integrate URL with Box’ and select a folder for organization.
  • Select a folder to save the workflow.
  • Click on the ‘Create’ button to finalize.
After creating your workflow, you will see a screen displaying the trigger and action setup. Here, you will define what event triggers the automation and what action follows.
For the trigger application, select URL and the event as ‘New Response’. Once selected, you will receive a webhook URL. This URL is crucial as it will connect your URL account with Pabbly Connect.
Copy the webhook URL provided. Next, log in to your URL account and navigate to the settings of the form you wish to integrate. Under the integrations tab, choose webhooks and enter the copied URL. After saving the integration, your URL is now connected with Pabbly Connect.
4. Configuring the Action Step in Pabbly Connect
Now that the trigger is set up, it’s time to configure the action step. Select Box as your action application and choose the action event as ‘Create a Subscriber’. This action will be executed whenever a new response is received from the URL form.
To connect your Box account with Pabbly Connect, click on ‘Connect’ and then ‘Add New Connection’. You will need to provide an access token. This token can be generated from your Box account settings under API access. Copy this token and paste it back into Pabbly Connect.
  • Select Box as the action application.
  • Choose ‘Create a Subscriber’ as the action event.
  • Paste the access token from your Box account.
After entering the necessary details, click on ‘Save and Send Request’ to finalize the action setup.
With both the trigger and action set up, it’s time to test the integration. Go back to your URL form and submit a test response. Ensure that you fill in all required fields accurately.
After submitting the test response, return to Pabbly Connect. You should see that the response has been captured successfully. Now, check your Box account to verify that a new subscriber has been created with the details provided in the test submission.
To confirm everything is working correctly, submit another test response in your URL form. If all steps were followed correctly, you should see the new details reflected in your Box account as well.
This tutorial showcased how to integrate URL and Box using Pabbly Connect. By following the steps outlined, you can automate your workflows and enhance productivity. With Pabbly Connect, managing integrations becomes seamless and efficient.
