1. Setting Up Pabbly Connect for Telegram and Trello Integration
To integrate Telegram and Trello, first, access Pabbly Connect. This platform allows you to automate workflows between different applications seamlessly. Start by signing in or creating a new account.
Once logged in, navigate to the ‘Connect’ section. Here, you can begin creating a new workflow. Click on the ‘Create Workflow’ button, and give your workflow a name that reflects its purpose, such as ‘Telegram to Trello Integration’.
2. Configuring Telegram as the Trigger Application
In this step, you will set up Telegram as the trigger application in Pabbly Connect. Select Telegram as your trigger app and choose the trigger event, which should be ‘New Message’. This means that every time a new message is received in your Telegram account, it will trigger the workflow.
You will need to connect your Telegram account by providing the necessary authentication details. Follow the prompts to authorize Pabbly Connect to access your Telegram account. Once connected, you can specify which channel or group you want to monitor for new messages.
3. Setting Up Trello as the Action Application
Next, you will configure Trello as the action application in Pabbly Connect. Choose Trello from the list of applications and select the action event as ‘Create Card’. This action will create a new card in Trello whenever a new message is received in Telegram.
Connect your Trello account by providing the required authentication details. After connecting, specify the board and list where you want the new Trello card to be created. You can also customize the card details by mapping fields from the Telegram message, such as the message text or sender information.
4. Testing the Integration Between Telegram and Trello
After configuring both applications, it’s time to test the integration in Pabbly Connect. Click on the ‘Test’ button to send a test message from Telegram. If everything is set up correctly, you should see a new card created in Trello based on the test message.
Check your Trello board to confirm that the card has been created successfully. This step ensures that the integration is functioning as intended and that messages from Telegram are being captured correctly to create Trello cards.
5. Activating Your Workflow in Pabbly Connect
Once you have tested the integration and are satisfied with the results, you can activate your workflow in Pabbly Connect. This will make the integration live, and it will start working in real-time. Click on the ‘Activate’ button to enable the workflow.
From now on, every time you receive a new message in your specified Telegram channel, a new Trello card will be automatically created. This automation saves you time and ensures that you never miss important messages that need to be tracked in Trello.
In this tutorial, we explored how to integrate Telegram and Trello using Pabbly Connect. By following these steps, you can instantly create Trello cards from new Telegram messages, streamlining your workflow and enhancing productivity.
