Learn how to integrate ThriveCart with System.io using Pabbly Connect. This detailed tutorial walks you through each step of the automation process. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start integrating ThriveCart with System.io, you need to access Pabbly Connect. First, open your browser and navigate to the Pabbly Connect website. If you are a new user, you can sign up for free and get 100 tasks every month. Existing users should click on the ‘Sign In’ button to log into their accounts.
Once logged in, you will see all Pabbly applications. Click on ‘Access Now’ under Pabbly Connect to open your dashboard. From here, you can create a new workflow by clicking on the ‘Create Workflow’ button, which allows you to automate the integration process.
In this section, you will create a new workflow to connect ThriveCart and System.io using Pabbly Connect. After clicking on ‘Create Workflow’, you will be prompted to name your workflow. Enter a suitable name like ‘Create System.io Contacts with Tags on ThriveCart Payment’ and select the folder for saving this workflow.
  • In the workflow window, choose ThriveCart as your trigger application.
  • Select the trigger event as ‘Product Purchase’.
After setting the trigger, click on ‘Connect’ to establish a connection with your ThriveCart account. You may need to enter an API key from your ThriveCart account, which can be found in the API/Webhook section under the settings menu.
3. Testing the Workflow with a Submission
Now that your workflow is set up, it’s time to test it using Pabbly Connect. After connecting ThriveCart, you need to select a product for which you want to trigger the workflow. Choose the Java course for beginners and set the product status to test mode.
To capture the response from your test submission, you will need to make a purchase. Open your ThriveCart account, find the product URL, and complete the checkout process with dummy details. This action will trigger the workflow in Pabbly Connect and send the details of the purchase.
4. Adding a Tag to the New Contact in System.io
Once the test submission is successful, the next step is to add a tag to the new contact in System.io using Pabbly Connect. You will add an action in your workflow to create a new contact in System.io. Select System.io as the action application and choose ‘Create Contact’ as the action event.
After connecting your System.io account, you will need to map the fields such as email, first name, and last name from the previous response. This mapping ensures that the data is dynamic and updates with each new submission. Make sure to include the tag name ‘Java BYOD’ for this contact.
  • Map the email, first name, last name, and other relevant fields.
  • Click on ‘Save and Send Test Request’ to finalize the action.
After saving, check your System.io account to verify that the new contact has been created with the assigned tag. This step is crucial for managing your email campaigns effectively.
5. Summary of the Pabbly Connect Workflow
In this final section, we will summarize the entire integration process using Pabbly Connect. The workflow starts with selecting ThriveCart as the trigger application and setting the trigger event to ‘Product Purchase’. This automation allows you to create a new contact in System.io whenever a purchase is made.
Next, you added a filter condition to ensure that the workflow only continues if the purchased product is the Java course for beginners. Finally, you created a new contact in System.io and tagged it appropriately. This entire process saves time and ensures that your communication remains relevant to your audience.
By using Pabbly Connect, you can automate the integration of various applications like ThriveCart and System.io, streamlining your business operations.
This tutorial demonstrated how to integrate ThriveCart with System.io using Pabbly Connect. By following these steps, you can automate your workflows efficiently and enhance your marketing efforts.
