Learn how to seamlessly integrate ThriveCart with Shopify using Pabbly Connect. Follow this detailed tutorial to automate customer creation effortlessly. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start integrating ThriveCart with Shopify, you first need to access Pabbly Connect. Begin by opening your browser and navigating to Pabbly’s official website. If you’re a new user, click on the ‘Sign Up for Free’ button to create an account.
Once registered, you will receive 100 free tasks to explore the capabilities of Pabbly Connect. Existing users can simply sign in. After logging in, locate the ‘Access Now’ button for Pabbly Connect on the dashboard, which will allow you to create a new workflow.
To create the workflow, click on the ‘Create Workflow’ option in Pabbly Connect. A dialog box will prompt you to name your workflow. Choose a relevant name, such as ‘ThriveCart to Shopify Integration’ and click ‘Create’.
  • Select ThriveCart as the trigger application.
  • Choose ‘Product Purchase’ as the trigger event.
  • Click on ‘Connect’ to establish a connection.
After selecting the trigger, follow the prompts to connect your ThriveCart account with Pabbly Connect. This connection will allow the automation to trigger whenever a new product is purchased, enabling customer creation in Shopify.
3. Connecting ThriveCart to Pabbly Connect
To connect ThriveCart, you need an API key. Log into your ThriveCart account and navigate to the ‘Settings’ section. Under ‘API and Webhooks’, you will find the option to create a new API key. Click on ‘Create API Key’ and name it, for example, ‘Shopify Customers’.
Copy the generated API key and paste it into Pabbly Connect to finalize the connection. Ensure that your product status is set to ‘Test Mode’ for testing purposes. After saving the connection, you can choose the specific product that will trigger the workflow.
4. Setting Up Shopify in Pabbly Connect
After successfully connecting ThriveCart, the next step involves setting up Shopify as the action application in Pabbly Connect. Select Shopify and choose ‘Create Customer’ as the action event. Click ‘Connect’ to establish a connection with your Shopify account.
  • Enter your Shopify store’s subdomain.
  • Generate an API access token by creating a new app in Shopify.
  • Map customer details from ThriveCart to Shopify.
Once the connection is established, map the customer details such as first name, last name, and email from the ThriveCart response. This mapping ensures that every new purchase automatically creates a new customer in Shopify using the provided details.
With both applications connected, it’s time to test the integration. Make a test purchase in ThriveCart for the selected product, ensuring you use valid customer details. After completing the purchase, return to Pabbly Connect and check for the response.
If the workflow is set up correctly, you will see a new customer created in Shopify. Refresh the Shopify customers’ section to confirm that the new customer appears with the details you provided during the test purchase.
This successful test confirms that the integration between ThriveCart and Shopify is functioning correctly through Pabbly Connect. You can now automate the process of customer creation seamlessly.
In this tutorial, we explored how to integrate ThriveCart with Shopify using Pabbly Connect. By following these steps, you can automate customer creation effortlessly, enhancing your business operations.
