Learn how to integrate Telegram with Jotform using Pabbly Connect. Follow our detailed tutorial to automate message sending effortlessly. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Telegram with Jotform, first, you need to access Pabbly Connect. This powerful integration platform allows you to automate workflows seamlessly. If you don’t have an account, you can create a free one in just two minutes.
Once logged in, navigate to the dashboard. Click on the blue button labeled ‘Create Workflow’. This is where you will set up your automation. Name your workflow something like ‘Send Telegram Message for Webhook Response’ to keep it organized.
In this step, you will set the trigger for your automation. Since you want to connect Telegram with Jotform using a webhook, select the option for Webhook in the trigger section of Pabbly Connect. This allows you to receive data from Jotform whenever a new form is submitted.
- Select ‘Webhook’ as the trigger application.
- Paste this URL into Jotform’s integration settings.
After pasting the URL into Jotform, ensure that the webhook is set up correctly to send data back to Pabbly Connect. This setup is crucial for receiving the form responses automatically.
3. Configuring Jotform to Work with Pabbly Connect
Next, you will need to configure Jotform to send data to the webhook URL generated by Pabbly Connect. Go to your Jotform account, select the form you want to use, and click on the settings option.
In the settings menu, find the integrations section. Search for the webhook option and paste the URL you copied from Pabbly Connect. Once you save this integration, Jotform will send data to Pabbly Connect every time the form is submitted.
4. Connecting Telegram to Pabbly Connect
Now that Jotform is set up, the next step is to connect Telegram with Pabbly Connect. In the action section of your workflow, select Telegram as the action application. Choose the action event as ‘Send Message’.
To connect Telegram, you will need a bot token from BotFather. Create a new bot by sending the command ‘/newbot’ and follow the instructions to get your token. Paste this token back into Pabbly Connect to establish the connection.
- Access BotFather in your Telegram app.
- Create a new bot and copy the token.
- Paste the token into Pabbly Connect to connect your bot.
After connecting, specify the chat ID where you want to send messages. This could be a group or channel. Ensure your bot is an admin in the group or channel to send messages successfully.
5. Testing and Activating the Integration
With everything set up, it’s time to test your integration. Submit a test response in Jotform. If everything is configured correctly, Pabbly Connect should receive the webhook response and send a message to your Telegram group or channel.
Check your Telegram app to see if the message was sent. If you see the message, congratulations! Your automation is now live. You can relax as Pabbly Connect will handle sending messages for every new form submission.
Integrating Telegram with Jotform using Pabbly Connect is a straightforward process that automates message sending. By following these steps, you can streamline your communication and ensure timely responses to inquiries. Start using Pabbly Connect today to enhance your workflow efficiency!
