Learn how to integrate Telegram with GoHighLevel using Pabbly Connect. This step-by-step tutorial covers all necessary actions for seamless automation. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To integrate Telegram with GoHighLevel, you first need to access Pabbly Connect. This platform allows you to automate tasks without coding. Simply visit the Pabbly Connect website and sign in or create a new account.
After signing in, you will be directed to the dashboard where you can manage your workflows. Click on the ‘Create Workflow’ button to start setting up your automation. This is where the integration process begins, and Pabbly Connect will serve as the bridge between your applications.
In this step, you will create a new workflow in Pabbly Connect. Name your workflow ‘Send Telegram Message for GoHighLevel Task’ and select a folder to save it. This helps in organizing your automation tasks effectively.
  • Click on ‘Create Workflow’ from the dashboard.
  • Provide a name for your workflow.
Now that the workflow is created, you will see two sections: Trigger and Action. The trigger will be ‘Lead Connector V2’ from GoHighLevel, while the action will be ‘Telegram Bot’. This setup ensures that whenever a new task is created in GoHighLevel, a message is sent via Telegram.
3. Set Up Trigger for GoHighLevel
The next step involves setting up the trigger in Pabbly Connect. Choose ‘Lead Connector V2’ as your trigger application and select the event ‘New Task Created’. This will capture the task details when a new task is added in GoHighLevel.
Once you select the trigger event, Pabbly Connect will provide a webhook URL. Copy this URL as it will be used in GoHighLevel to send data to Pabbly Connect. This webhook acts as a bridge for data transfer between GoHighLevel and Pabbly Connect.
4. Configure GoHighLevel for Webhook
Now, you need to set up the webhook in GoHighLevel. Go to your GoHighLevel account and navigate to the Automation section. Here, create a new workflow that triggers when a task is added.
  • Select ‘Create Workflow’ and choose ‘Start from Scratch’.
  • Name your workflow and set the trigger to ‘Task Added’.
  • Select ‘Webhook’ as the action and paste the copied URL from Pabbly Connect.
After saving the workflow, publish it. Now, whenever a new task is created in GoHighLevel, the details will be sent to Pabbly Connect via the webhook.
5. Set Up Action to Send Telegram Message
With the trigger and webhook ready, the final step is to set up the action in Pabbly Connect to send a message to your Telegram channel. Choose ‘Telegram Bot’ as the action application and select ‘Send Text Message’ as the action event.
Connect your Telegram bot by entering the token you received from the BotFather. After successfully connecting, enter the chat ID of the Telegram group where you want to send messages. Map the task details like title and description into the message format.
In this tutorial, we covered how to integrate Telegram with GoHighLevel using Pabbly Connect. This setup allows you to automate notifications for new tasks seamlessly. Automating your workflow can enhance productivity and ensure timely communication with your team.
