Learn how to integrate Telegram messages with WhatsApp using Pabbly Connect in this detailed step-by-step tutorial. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start the integration of Telegram messages with WhatsApp, you need to access Pabbly Connect. Begin by navigating to the Pabbly website and clicking on the ‘Products’ section, then select ‘Connect’. This will take you to the Pabbly Connect dashboard.
Once on the dashboard, sign in to your account or create a new one if you haven’t already. After signing in, you can start creating your workflow. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Telegram to WhatsApp’. This sets the foundation for your integration process.
2. Setting Up Telegram as the Trigger Application
In this step, you will set Telegram as the trigger application in Pabbly Connect. Choose Telegram from the list of applications and select the trigger event as ‘Set Webhook’ or ‘Watch Updates’. This event will trigger the workflow when a new message arrives on Telegram.
  • Select the Telegram application from the trigger options.
  • Choose the event ‘Set Webhook’ or ‘Watch Updates’.
  • Click the connect button to link your Telegram bot to Pabbly Connect.
To connect Telegram, you will need a bot token. Use the BotFather on Telegram to create a new bot and obtain this token. Once you have the token, paste it into the connection field in Pabbly Connect and click ‘Save and Send Test Request’ to complete the setup.
3. Integrating Chat API for WhatsApp Messaging
Now that your Telegram setup is complete, the next step involves integrating Chat API with Pabbly Connect. This is crucial as Chat API will facilitate sending messages to WhatsApp. Choose Chat API as the action application and select the action event as ‘Get Contacts or Group’.
Connect Chat API by entering the API URL and token, which you can find in your Chat API account. After saving the credentials, proceed by clicking on ‘Save and Send Test Request’ to retrieve your contacts or group details.
  • Select Chat API as the action application.
  • Choose ‘Get Contacts or Group’ as the action event.
  • Enter required API URL and token for Chat API.
After retrieving the contact details, you can select the specific group where you want to send the messages. This step is essential for ensuring that your messages are sent to the right audience on WhatsApp.
4. Sending Messages to WhatsApp
With the group details obtained, the next step is to send messages to WhatsApp using Pabbly Connect. Add a new action window and select Chat API again, but this time choose the action event as ‘Send Message’. This allows you to configure the message details that will be sent to WhatsApp.
For the action event, you need to input the group ID and the message content. Make sure to copy the group ID from the previous step rather than mapping it, as it may not always appear in the same section. Once you have entered all the necessary details, click on ‘Save and Send Test Request’.
Select Chat API for sending messages. Choose ‘Send Message’ as the action event. Input the group ID and message content accurately.
Once the message is sent, you can check your WhatsApp to confirm that the message has been received. This completes the integration process, allowing you to sync Telegram messages directly to WhatsApp.
5. Conclusion and Benefits of Using Pabbly Connect
In this tutorial, we successfully integrated Telegram and WhatsApp using Pabbly Connect. By following the steps outlined, you can automate the process of sending Telegram messages to WhatsApp without any coding knowledge. This integration not only saves time but also ensures that important messages are delivered promptly.
Pabbly Connect serves as a powerful tool for automating workflows and bridging the gap between different applications. Whether you are managing group communications or need to keep track of important updates, this integration can significantly enhance your productivity.
By leveraging Pabbly Connect, you can seamlessly connect various applications and streamline your messaging processes, making your communication more efficient and effective.
