Learn how to easily integrate Teachable with MailerLite using Pabbly Connect. Follow this step-by-step guide for seamless automation. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Teachable with MailerLite, you first need to access Pabbly Connect. Open your web browser and type in the URL Pabbly.com. This will take you to the Pabbly homepage where you can either log in or create a new account.
If you are a new user, click on ‘Sign Up for Free’ to create your account. Existing users can click on ‘Sign In’ to access their dashboards. Once logged in, navigate to Pabbly Connect to begin the integration process.
After accessing Pabbly Connect, you will see a dashboard displaying all your workflows. To create a new workflow, click on the ‘Create Workflow’ button located in the top right corner. Name your workflow appropriately, such as ‘Teachable to MailerLite’ and click on ‘Create’.
- Name your workflow (e.g., ‘Teachable to MailerLite’).
- Click ‘Create’ to proceed.
This will set up a new workflow with options for triggers and actions. In this case, Teachable will be your trigger application, and you will select it to start the integration.
3. Setting Up Teachable as the Trigger Application
In the newly created workflow, select Teachable as the trigger application. Choose the trigger event labeled ‘New Enrollment’. This event will initiate the workflow whenever a new student enrolls in a course on Teachable.
Next, you will need to connect your Teachable account to Pabbly Connect. A webhook URL will be generated for you. Copy this URL as it will be needed to set up a webhook in your Teachable account.
- Select ‘New Enrollment’ as the trigger event.
- Copy the generated webhook URL.
- Connect this webhook in your Teachable account settings.
After setting up the webhook, you will need to perform a test enrollment in Teachable to capture the response in Pabbly Connect.
4. Performing a Test Enrollment in Teachable
To test the integration, go to your Teachable account and select a course, such as ‘PHP for Beginners’. From the student section, click on ‘Add Students’ and fill in the details for a test student.
Make sure to include the student’s name and email address. Once you have entered the details, enroll the student in the course. After enrollment, return to Pabbly Connect to check if the response has been captured successfully.
Select the course to enroll the student. Fill in the student details (name and email). Click ‘Enroll’ to complete the process.
Once the test enrollment is done, you should see a response in Pabbly Connect indicating the new student has been successfully added.
5. Adding New Subscriber in MailerLite
Now that you have captured the new enrollment response, the next step is to add this student as a new subscriber in MailerLite. In Pabbly Connect, select MailerLite as the action application and choose the action event ‘Add or Update Subscriber’.
You will need to connect your MailerLite account by entering the API key, which you can find in your MailerLite account under the integrations section. After connecting, map the student details from the Teachable response to the corresponding fields in MailerLite.
Select MailerLite as the action application. Enter your MailerLite API key to connect. Map the student details to MailerLite fields.
After mapping, send a test request to confirm that the integration works. Check your MailerLite account to see if the new subscriber appears successfully.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Teachable with MailerLite. By following these steps, you can automate the process of adding new subscribers in MailerLite whenever a new enrollment occurs in Teachable, enhancing your workflow efficiency.
