Learn how to automate adding Mailchimp subscribers from Teachable enrollments using Pabbly Connect with this detailed tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Setting Up Pabbly Connect for Teachable and Mailchimp Integration
To start integrating Teachable with Mailchimp, you will first need to access Pabbly Connect. This platform allows you to automate tasks between different applications seamlessly. Begin by signing up for a free account on Pabbly Connect, which can be done in just a few minutes.
Once logged in, navigate to the dashboard and click on ‘Create Workflow’. You can name your workflow, for instance, ‘Teachable to Mailchimp’. This sets up the framework for the automation you will create.
2. Configuring the Teachable Trigger in Pabbly Connect
In this step, you will set up the trigger for the workflow. The trigger is what initiates the automation when a new event occurs. Select Teachable as the app in the trigger window of Pabbly Connect.
- Choose the trigger event as ‘New Enrollment’.
- Go to your Teachable account and navigate to Settings > Webhooks.
- Add the copied webhook URL and select the event for new enrollment.
After saving the webhook settings, every new enrollment in your Teachable courses will send data to Pabbly Connect, allowing it to trigger the next action in your workflow.
3. Adding Mailchimp as an Action in Pabbly Connect
Now that you have set up the trigger, it’s time to add an action that will occur when the trigger is activated. In the action window, search for Mailchimp and select it as the app. using Pabbly Connect
Choose the action event as ‘Add New Member with Custom Fields’. You will need to connect your Mailchimp account by entering your API key and Data Center ID, which you can find in your Mailchimp account settings under Extras > API keys.
Once connected, select the audience list in Mailchimp where you want to add the new subscribers. Map the email address and other details received from Teachable to Mailchimp fields. This ensures that every new enrollment is reflected in your Mailchimp audience.
With your workflow set up, it’s crucial to test it to ensure everything works seamlessly. To do this, enroll a new user in your Teachable course. The details of this enrollment will be sent to Pabbly Connect.
Check the Pabbly Connect workflow to see if the trigger has received the enrollment data. If successful, you should see the user details appear in the workflow. Next, check your Mailchimp account to confirm that the new subscriber has been added with the correct information.
This testing phase is essential to confirm that your integration is functioning as intended. If you encounter any issues, revisit the steps to ensure all settings are correctly configured in Pabbly Connect.
5. Conclusion: Automate Your Teachable and Mailchimp Integration with Pabbly Connect
Using Pabbly Connect allows you to automate the process of adding new Teachable enrollments as subscribers in Mailchimp effortlessly. This integration saves time and ensures that your marketing lists are always updated.
By following the steps outlined in this tutorial, you can set up a powerful automation that enhances your workflow. Try it out and experience the benefits of seamless integration between Teachable and Mailchimp!
