Learn how to integrate Stripe and WooCommerce using Pabbly Connect. This tutorial provides a detailed, step-by-step guide to automate customer creation. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Accessing Pabbly Connect for Stripe and WooCommerce Integration
To begin the integration process using Pabbly Connect, first, navigate to the Pabbly website by typing ‘Pabbly.com’ in your browser. Once on the homepage, hover over the ‘Products’ tab and select ‘Connect’ from the dropdown menu.
After clicking on ‘Connect’, you will be prompted to sign in to your account. If you don’t have an account yet, you can create one easily. Pabbly Connect offers a free trial plan, allowing you to test the integration features without any coding skills required.
Once logged into Pabbly Connect, click on the ‘Create Workflow’ button located in the dashboard. You will be prompted to name your workflow; for this integration, name it ‘Stripe to WooCommerce’ and click on ‘Create’ to proceed.
Next, you will see the trigger window. Here, select ‘Stripe’ as your app in the ‘Choose App’ dropdown. For the trigger event, choose ‘New Customer’. This setup means that every time a new customer is created in Stripe, it will trigger the workflow to add that customer to WooCommerce.
3. Setting Up Stripe Webhook in Pabbly Connect
In this step, you will connect Pabbly Connect with your Stripe account. Go to your Stripe dashboard, click on ‘Developers’, then select ‘Webhooks’. Click on ‘Add Endpoint’ to create a new webhook.
Copy the webhook URL provided by Pabbly Connect and paste it into the endpoint URL field in Stripe. Ensure to remove the ‘http’ part from the URL. Set the event to ‘New Customer’ and click on ‘Add Endpoint’. This step allows Stripe to send customer data to Pabbly Connect.
4. Capturing Webhook Response from Stripe
Now that the webhook is set up, return to Pabbly Connect and click on ‘Capture Webhook Response’. This will wait for data from Stripe. To generate a response, create a new customer in your Stripe account with all the required details.
Once the customer is created, Pabbly Connect will capture the data. You should see the customer information such as name, email, and address in the webhook response section. This confirms that the integration is working correctly.
5. Integrating WooCommerce with Pabbly Connect
After capturing the webhook response, the next step is to send this data to WooCommerce. In Pabbly Connect, click on the plus button to add an action step. Choose ‘WooCommerce’ as the app and select ‘Add a New Customer’ as the action event.
Connect your WooCommerce account by entering the necessary details like the website URL, consumer key, and consumer secret. These can be generated from your WooCommerce settings under ‘Advanced’ and ‘REST API’. Ensure all fields are filled correctly before saving.
  • Map the customer data received from Stripe to the corresponding fields in WooCommerce.
  • Test the integration by sending a test request to WooCommerce.
  • Check WooCommerce to confirm that the new customer appears in your customer list.
Once the test is successful, you will see the new customer in your WooCommerce account. This confirms that your integration between Stripe and WooCommerce via Pabbly Connect is complete and functioning properly.
In this tutorial, we demonstrated how to integrate Stripe with WooCommerce using Pabbly Connect. This integration allows for automatic customer creation and seamless data flow between the two platforms. By following the steps outlined, you can easily set this up and enhance your e-commerce operations.
