Learn how to automate your Stripe payments with Flodesk email marketing using Pabbly Connect. Follow this detailed tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
1. Setting Up Pabbly Connect for Stripe and Flodesk Integration
To begin, access Pabbly Connect and create a new workflow. This platform allows you to automate tasks between applications seamlessly. Start by logging into your Pabbly Connect account or create a free account if you are a new user.
After logging in, click on the blue button labeled ‘Create Workflow’. Name your workflow something descriptive, such as ‘Create Subscriber in Flodesk on Stripe Payment’. Then click on the ‘Create’ button to initiate your automation.
2. Connecting Stripe to Pabbly Connect
In this section, you will connect Stripe to Pabbly Connect. Select Stripe as your trigger application. The trigger event should be set to ‘New Charge’ which indicates that the automation will start when a new payment is received.
  • Choose ‘New Charge’ as the trigger event in Stripe.
  • Go to Stripe’s dashboard, under Developers, and select Webhooks.
  • Click ‘Add Endpoint’ and paste the webhook URL.
  • Select the event type ‘charge.succeeded’ for Stripe to listen for successful payments.
Once you have set this up, make a test payment in Stripe to ensure that data is received in Pabbly Connect. This confirms that the integration is working correctly.
3. Creating Subscribers in Flodesk via Pabbly Connect
Now that Stripe is connected to Pabbly Connect, you will set up Flodesk as the action application. Choose Flodesk and select the action event ‘Create or Update Subscriber’. This will allow you to add new customers to your email list automatically.
Connect your Flodesk account by providing the necessary access. Once connected, you will need to map the fields from the Stripe payment to the subscriber details in Flodesk. For example, map the email address from Stripe to the email field in Flodesk.
  • Map the email address from the Stripe response to the Flodesk email field.
  • Use the full name field to split into first and last names for Flodesk.
  • Ensure all required fields in Flodesk are filled with the corresponding Stripe data.
This step ensures that every time a payment is processed, the customer is automatically added as a subscriber in Flodesk.
4. Adding Subscribers to Segments in Flodesk Using Pabbly Connect
In this step, you will further enhance your automation by adding the newly created subscribers to specific segments in Flodesk. Return to Pabbly Connect and add another action step to connect to Flodesk again.
Choose the action event ‘Add Existing Subscriber to Segment’. Select the segment you want your new subscribers to join, such as ‘All Stripe Customers’. Map the email address from the previous step to ensure the subscriber is added correctly.
Select the segment you want to add subscribers to. Map the email address from the previous step to the subscriber email field. Test the integration to ensure subscribers are added to the segment.
This automation ensures that not only are your customers added as subscribers, but they are also categorized into segments for targeted email marketing.
5. Final Testing and Conclusion of the Integration Process
After completing all steps, it’s crucial to test the entire workflow. Make another test payment in Stripe and check if the subscriber is created in Flodesk and added to the specified segment. This confirms that Pabbly Connect is functioning as intended.
If everything works correctly, you will see the new subscriber in your Flodesk account along with the correct details and segment assignment. This automation saves you time and ensures your email marketing is always up to date with your latest customers.
By using Pabbly Connect, you can easily integrate multiple applications, automate your workflows, and focus on growing your business without manual data entry. This integration between Stripe and Flodesk showcases the power of automation in enhancing your marketing efforts.
In summary, this tutorial demonstrates how to utilize Pabbly Connect to seamlessly integrate Stripe with Flodesk. By automating the process of adding subscribers and managing segments, you can enhance your email marketing efficiency.
