Learn how to integrate Stripe with Drip using Pabbly Connect to automate subscriber creation for every new Stripe customer. Follow our detailed tutorial. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect for Stripe and Drip Integration
To integrate Stripe with Drip, you will first need to access Pabbly Connect. This platform allows you to automate workflows between different applications seamlessly. If you don’t have an account, you can create one in just two minutes using the ‘Sign Up Free’ button on the Pabbly Connect dashboard.
Once logged in, locate the blue button labeled ‘Create Workflow’. Click on this button to start the integration process. Here, you will need to name your workflow, for example, ‘Sync Stripe Customers with Drip Software Automatically’. After naming, click on ‘Create’ to proceed.
2. Setting Up the Trigger Event in Pabbly Connect
In this step, you will set up the trigger event using Pabbly Connect. Select Stripe as the application and choose the trigger event, which is ‘Customer Created’. This means that every time a new customer is added in Stripe, this event will trigger the automation.
- Select ‘Stripe’ as the application
- Choose ‘Customer Created’ as the trigger event
- Copy the webhook URL provided by Pabbly Connect
Next, navigate to your Stripe dashboard. Ensure you are in test mode and go to the ‘Developer’ section. Under ‘Webhooks’, click on ‘Add Endpoint’ and paste the copied URL. Then, select the event ‘customer.created’ and add this event to complete the setup.
3. Testing the Connection Between Stripe and Pabbly Connect
Now that you have set up the trigger, it’s time to test the connection using Pabbly Connect. Make a dummy purchase in Stripe to ensure that the webhook is functioning correctly. Log into your Stripe account and create a test customer.
- Use dummy details for the customer, including an email and payment information
- Complete the transaction to trigger the webhook
- Check Pabbly Connect for the received data
If everything is set up correctly, you will see the customer data appear in Pabbly Connect, indicating that the connection is working successfully. This means your integration is functioning as intended.
4. Setting Up Drip Integration in Pabbly Connect
After confirming the Stripe connection, the next step is to set up the Drip integration using Pabbly Connect. Select Drip as the action application and choose the action event ‘Create or Update Subscriber’. This allows you to add new subscribers automatically whenever a new customer is created in Stripe.
You will need to connect your Drip account by providing the token and password. To find these credentials, refer to the Drip documentation. Once you have entered the token and password in Pabbly Connect, click ‘Save’. This will establish the connection with Drip.
5. Mapping Customer Data to Create Subscribers in Drip
In this final step, you will map the customer data from Stripe to create a subscriber in Drip using Pabbly Connect. The fields you need to fill include the first name, last name, and email address of the customer. You can easily map these fields by selecting the corresponding data from the previous step.
After mapping the necessary fields, click on ‘Save and Send Test Request’. This will send the data to Drip and create a new subscriber based on the information provided. You can check your Drip account to confirm that the subscriber has been added successfully.
Integrating Stripe with Drip using Pabbly Connect automates the process of adding new customers as subscribers. By following these steps, you can ensure that every new payment made in Stripe is reflected in your Drip marketing automation software. This integration not only saves time but also enhances your marketing efforts by keeping your subscriber list updated automatically.
