Learn how to integrate Stripe with AWeber in real-time using Pabbly Connect. Follow this detailed guide for seamless automation. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start integrating Stripe with AWeber, first access Pabbly Connect by typing Pabbly.com in your browser. This platform serves as the central integration hub for connecting various applications seamlessly.
Once on the Pabbly website, navigate to the products section and select Pabbly Connect. Click on the sign-in button to log into your account. If you don’t have an account, you can create one quickly. Pabbly Connect offers a free plan to try out integrations.
After logging into Pabbly Connect, click on the ‘Create Workflow’ button. Name your workflow something like ‘Stripe to AWeber’ to identify its purpose easily. This workflow will manage the data flow from Stripe to AWeber.
In the trigger window, select Stripe as the application to connect. Choose the trigger event as ‘New Charge’ since this will activate the workflow when a new payment is made in Stripe.
3. Set Up Stripe Webhook for Data Capture
To capture data from Stripe, you must set up a webhook. In your Stripe account, navigate to the Developers section and click on Webhooks. Here, click on ‘Add Endpoint’ to create a new webhook.
In the ‘Endpoint URL’ field, paste the webhook URL provided by Pabbly Connect. Make sure to remove the HTTP part before pasting. Set the event type to ‘Charge Succeeded’ to ensure you receive data when a charge is successful.
4. Retrieve Customer Information from Stripe
Once the webhook is set up, go back to Pabbly Connect and click on ‘Capture Webhook Response’. This action will wait for data from Stripe. Now, create a dummy charge in Stripe to test the integration.
After creating the charge, return to Pabbly Connect to see if the data has been captured. You should see charge details but may notice that customer information is missing. To retrieve this, add another action in your workflow by selecting Stripe again and choosing ‘Retrieve Customer’.
5. Send Customer Data to AWeber
Now that you have the customer information, it’s time to send it to AWeber. Add another action in Pabbly Connect and select AWeber as the application. Choose ‘Add Subscriber’ as the action event.
Connect your AWeber account by allowing access. Map the retrieved customer data from Stripe to the AWeber fields, ensuring that the full name and email are correctly mapped. Finally, click on ‘Save and Send Test Request’ to verify if the subscriber is added successfully in AWeber.
In this guide, we detailed how to integrate Stripe with AWeber using Pabbly Connect. This integration allows for real-time subscriber updates whenever a new charge is made. With Pabbly Connect, you can automate workflows efficiently without coding skills.
