Learn how to seamlessly integrate Stripe and Typeform using Pabbly Connect to create customers for every new Typeform entry in real-time. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Typeform and Stripe, access Pabbly Connect by visiting Pabbly.com. Hover over the products menu and select Connect. You will need to sign in or create an account if you’re new to the platform.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can explore various automation solutions. Pabbly Connect offers a free plan, allowing you to set up this integration without any upfront costs.
Once you are on the Pabbly Connect dashboard, click on the ‘Create a Workflow’ button in the top right corner. Name your workflow, such as ‘Typeform to Stripe,’ and click on Create. This initiates the workflow setup.
In the trigger window, select Typeform as the app. Choose the method ‘New Entry’ as your trigger event. This action will initiate the workflow whenever there is a new entry submitted in Typeform.
  • Select the Typeform app
  • Choose the trigger method: New Entry
  • Connect with Typeform by authorizing access
After connecting, select the form you want to use from your Typeform account. This step is crucial as it defines which form submissions will trigger the customer creation process in Stripe.
After selecting your Typeform, you will receive a webhook URL generated by Pabbly Connect. This URL is where Typeform will send the data for new entries. Copy this URL and save it in your Typeform settings as the webhook destination.
To ensure the connection is established, go back to Pabbly Connect and click on ‘Save and Send Test Request’. This will test the connection between Typeform and Pabbly Connect. Once successful, click on ‘Capture Webhook Response’ to capture the data sent from Typeform.
  • Copy the webhook URL from Pabbly Connect
  • Paste it into your Typeform settings
  • Test the connection by sending a test request
After capturing the webhook response, you can view the data collected from your Typeform entry, confirming that Pabbly Connect is receiving the information correctly.
With the data captured, click the plus button to add an action step in Pabbly Connect. Choose Stripe as the app and select ‘Create Customer’ as the action method. This step will create a new customer in Stripe for every new Typeform entry.
To connect with Stripe, you will need to enter your Stripe API secret key. Navigate to your Stripe account, go to the Developers section, and find your API keys. Copy the secret key and paste it into Pabbly Connect.
Select Stripe as the app
Choose the action method: Create Customer
Enter your Stripe API secret key
After entering the API key, map the fields from the Typeform entry to the appropriate fields in Stripe, such as email and name. Once mapping is complete, click on ‘Save and Send Test Request’ to create the customer in Stripe.
To ensure the integration works correctly, make a test entry in your Typeform. Submit the form with sample data and check if the customer appears in your Stripe account. This confirmation verifies that the integration via Pabbly Connect is functioning as intended.
After submitting the test entry, return to your Stripe dashboard and refresh the customer list. You should see the new customer created based on the Typeform entry, confirming that the data flow between Typeform and Stripe is active.
Submit a test entry in Typeform
Check the Stripe dashboard for the new customer
Ensure all details are correctly mapped
This integration means that every time a new entry is made in Typeform, a corresponding customer will be created in Stripe automatically, streamlining your workflow.
In summary, using Pabbly Connect to integrate Typeform and Stripe allows for seamless customer creation with every new entry. This automation enhances efficiency and ensures accurate data flow between your applications.
Check out Pabbly Connect – Automate your business workflows effortlessly!
Sign Up Free – Start your journey with ease!
10,000+ Video Tutorials – Learn step by step!
Join Pabbly Facebook Group – Connect with 21,000+ like minded people!
