Learn how to seamlessly integrate Stripe and Demio for webinar registration using Pabbly Connect. Follow this step-by-step guide to automate your workflow. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To begin the integration process, you need to access Pabbly Connect. Start by typing ‘Pabbly.com’ in your browser and press enter. This will take you to the Pabbly website where you can navigate to the products section.
Click on the option labeled ‘Connect’ at the bottom of the page. Once on the Pabbly Connect page, sign in to your existing account or create a new account, which can be done in just a few minutes. Pabbly Connect offers a free trial plan to test the integration features.
In this step, you will create a new workflow in Pabbly Connect to integrate Stripe with Demio. Click on the ‘Access Now’ button on the top right corner and then select ‘Create Workflow’. A dialog box will prompt you to name your workflow.
Enter a name such as ‘Stripe to Demio’ and click on ‘Create’. This will open the trigger window where you will select the app and method. Choose ‘Stripe’ as the app and ‘New Customer’ as the method, which serves as the trigger event for this integration.
3. Setting Up Stripe to Capture New Customer Data
Now, you need to set up Stripe to send data to Pabbly Connect. Go to your Stripe account, navigate to the ‘Developers’ section, and select ‘Webhooks’. Click on ‘Add Endpoint’ to set up a new webhook.
  • Copy the webhook URL from Pabbly Connect and paste it in the endpoint URL field.
  • Set the event to ‘customer.created’ to ensure data is sent when a new customer is created.
  • Click on ‘Add Endpoint’ to finalize the setup.
This integration allows Pabbly Connect to capture new customer data from Stripe, which is essential for creating webinar registrations in Demio.
4. Syncing Customer Data to Demio
With the Stripe integration complete, the next step is to sync the captured customer data to Demio using Pabbly Connect. Click on the plus button in the action window and select ‘Demio’ as the app, then choose ‘Create Webinar Registration’ as the method.
Connect to Demio by entering your API key and API secret from your Demio account settings. Once connected, you will see fields for event name, email, and other details. Map the customer data received from Stripe to these fields.
  • For the event, select the appropriate webinar from Demio.
  • Map the customer’s name and email from the captured data.
  • Click ‘Save and Send Test Request’ to complete the registration process.
This step ensures that every new customer registered in Stripe is automatically signed up for your webinar in Demio through Pabbly Connect.
5. Testing the Integration
After setting everything up, it’s crucial to test the integration to ensure it works correctly. Create a dummy customer in Stripe with the name ‘Michael Berry’ and an email address like ‘[email protected]’.
Once the customer is created, check the Demio account to see if the registration for the webinar appears successfully. If the integration is working, you should see Michael’s registration reflected in Demio.
This confirms that Pabbly Connect is effectively facilitating the data flow between Stripe and Demio, allowing you to automate your webinar registrations seamlessly.
Using Pabbly Connect to integrate Stripe and Demio for webinar registration simplifies the process and automates workflows. You can now create registrations instantly for new customers, enhancing your webinar management.
