Learn how to integrate SLE, Commander, Link, and Box using Pabbly Connect through a step-by-step tutorial. Automate your processes easily today! Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To start integrating SLE, Commander, Link, and Box, you must first access Pabbly Connect. Open your browser and go to the Pabbly website.
If you are a new user, click on ‘Sign Up for Free’ to create an account. Existing users can simply click on ‘Sign In’. After logging in, navigate to the Pabbly Connect application by clicking on ‘Access Now’.
Once you are in Pabbly Connect, the next step is to create a workflow. Click on the ‘Create Workflow’ button to start. You will be prompted to name your workflow and choose a folder for it.
  • Name your workflow something descriptive like ‘Create SLE Subscriber from Weblum Form Submission’.
  • Select the folder where you want to save this workflow.
After naming and selecting the folder, click on ‘Create’. This opens the workflow window where you can set triggers and actions.
In this section, you will set up the trigger for your workflow using Pabbly Connect. The trigger application in this case is Weblum. Click to select Weblum as your trigger application.
For the trigger event, choose ‘New Form Submission’. You will then receive a webhook URL that you need to copy. This URL will be used to connect your Weblum account to Pabbly Connect.
  • Go to your Weblum account settings and select ‘Integrations’.
  • Add the copied webhook URL to your Weblum form.
Once the webhook is added, you will see a confirmation message indicating that the connection has been established. Now, you need to perform a test submission to capture the response in Pabbly Connect.
4. Performing a Test Submission for Data Capture
After setting up the trigger, the next step is to perform a test submission to ensure data is captured correctly in Pabbly Connect. Open the form linked to your Weblum account and fill it out with sample data.
Submit the form and return to your Pabbly Connect workflow. Here, you should see that Pabbly has captured the response from your submission. If the data appears correctly, you are ready to set up the action step.
Ensure that the captured data includes fields like full name, phone number, and email. If you are using a trial account, you may see placeholder data instead of your actual input.
Once you confirm that the data is captured, you can proceed to set up the action step in your workflow.
5. Setting Up the Action to Create Subscribers
Now, it’s time to set up the action step in your workflow using Pabbly Connect. For the action application, select SLE as you want to create a new subscriber in your SLE account.
Choose the action event as ‘Add Subscriber’. You will need to connect your SLE account by providing the necessary API credentials. This includes your API ID and secret, which can be found in your SLE account settings.
Log into your SLE account and navigate to the account settings to find API information. Copy the API ID and secret and paste them into the required fields in Pabbly Connect.
After saving the connection, you will need to map the fields from the trigger step to the action step. This ensures that the correct data from your Weblum form submission is sent to SLE. Once all fields are mapped, test the setup to confirm that a new subscriber is created successfully in SLE.
In this tutorial, we explored how to integrate SLE, Commander, Link, and Box using Pabbly Connect. We covered accessing Pabbly Connect, creating workflows, setting up triggers and actions, and performing test submissions. This integration allows for seamless automation of subscriber creation from Weblum form submissions.
