Learn how to integrate Simply and Legion with Instagram Lead Ads using Pabbly Connect in this step-by-step tutorial. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To integrate Simply and Legion with Instagram Lead Ads, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect website by typing ‘Pabbly.com/connect’ into your browser. Once there, sign in to your account by clicking on the ‘Sign In’ button at the top right corner.
If you are new to Pabbly Connect, you can create a free account which offers 100 tasks monthly. After signing in, you will be directed to the Pabbly Connect dashboard where you can manage your workflows.
In this step, you will create a new workflow to automate the process. Click on ‘Create Workflow’ on your Pabbly Connect dashboard. You will need to name your workflow, such as ‘Add or Update SendGrid Contact on Instagram Lead Ads’. using Pabbly Connect
- Select the folder where you want to save this workflow.
- Click on ‘Create’ to finalize the workflow setup.
Once the workflow is created, you will see two boxes labeled ‘Trigger’ and ‘Action’. The trigger will be set to Instagram Lead Ads, and the action will be to add or update a contact in SendGrid.
Now, you will configure the trigger using Instagram Lead Ads. Select Instagram Lead Ads as your trigger application and choose ‘New Lead’ as the trigger event. Click on ‘Connect’ to establish the connection. using Pabbly Connect
If you don’t have an existing connection, you will need to create a new one by clicking on ‘Add New Connection’. You will be prompted to log in to your Facebook account since Instagram is linked with Facebook. Once authorized, return to Pabbly Connect.
- Select the Facebook page associated with your Instagram ads.
- Choose the specific lead form you created for your ads.
With these details set, click on ‘Save and Send Test Request’. This step will prompt you to submit a test lead through your Instagram Lead Ads to capture the response in Pabbly Connect.
4. Finalizing the Integration with SendGrid
After successfully capturing the lead data, you will proceed to the action step. Select SendGrid as your action application and choose ‘Add or Update Contact’ as the action event. Click on ‘Connect’ to link SendGrid with Pabbly Connect.
To create this connection, you will need an API key from your SendGrid account. Navigate to the API keys section in your SendGrid account settings, create a new API key, and paste it into Pabbly Connect. Click ‘Save’ to complete the connection.
Select the list in SendGrid where you want to add the contact. Map the fields from the Instagram lead data to the corresponding fields in SendGrid.
After mapping the fields, click on ‘Save and Send Test Request’. This will send the data to SendGrid and create a contact based on the information received from Instagram.
To ensure that the integration is working correctly, return to your Instagram Lead Ads testing tool and submit a new lead form. After submitting, check your SendGrid account to confirm that the new contact has been added.
Refresh the contacts list in SendGrid, and you should see the new lead details populated. This confirms that Pabbly Connect has successfully automated the process of adding new leads from Instagram to SendGrid.
Repeat the testing process with different lead details to verify that the integration consistently works as expected. Each time a new lead is submitted, it should appear in your SendGrid account automatically.
In this tutorial, we demonstrated how to integrate Simply and Legion with Instagram Lead Ads using Pabbly Connect. By following these steps, you can automate the process of adding new leads to your SendGrid account efficiently.
