Learn how to automate adding Sendinblue contacts from new WordPress users using Pabbly Connect. Streamline your email marketing efforts effortlessly! Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
1. Setting Up Pabbly Connect for WordPress and Sendinblue Integration
To begin integrating Sendinblue with WordPress, you need to access Pabbly Connect. This platform allows you to automate the process of adding new WordPress users as contacts in Sendinblue. Start by visiting the Pabbly Connect website, where you can sign up for a free account and explore its automation capabilities.
Once signed up, log in to your Pabbly Connect account. From the dashboard, click on the ‘Create Workflow’ button. Name your workflow something descriptive, such as ‘Add Sendinblue Contacts from New WordPress Users’ and click on the ‘Create’ button. This setup will enable you to automate the integration process efficiently.
2. Configuring WordPress Trigger in Pabbly Connect
In this step, you will set up the trigger for your automation using Pabbly Connect. Select WordPress as your trigger application and choose the trigger event as ‘New User.’ This event will initiate the workflow whenever a new user registers on your WordPress site.
  • Choose ‘WordPress’ as the trigger application.
  • Select ‘New User’ as the trigger event.
  • Copy the provided webhook URL for later use.
After selecting the trigger, follow the instructions to set up the connection with your WordPress site. You will need to install the WP Webhooks plugin on your WordPress dashboard. This plugin allows Pabbly Connect to receive data from your WordPress site whenever a new user registers.
3. Setting Up WP Webhooks on WordPress
To connect WordPress with Pabbly Connect, install the WP Webhooks plugin. Navigate to the Plugins section in your WordPress dashboard, click on ‘Add New’, and search for WP Webhooks. After installation, go to the settings of the WP Webhooks plugin.
  • Click on ‘Send Data’ in the WP Webhooks settings.
  • Select ‘User Created’ under WordPress options.
  • Paste the webhook URL from Pabbly Connect and save the settings.
After saving, your WordPress site will now send data to Pabbly Connect whenever a new user registers. You can now proceed to test this connection by creating a new user in WordPress.
4. Testing the Integration with a New User
Now it’s time to test the integration. Create a new user in your WordPress site by navigating to the Users section and clicking on ‘Add New’. Fill in the necessary details such as username, email, first name, and last name. Once done, click on ‘Add New User’. This action will trigger the webhook set up in Pabbly Connect.
After creating the user, return to Pabbly Connect to check if the data has been captured correctly. You should see the details of the new user in the response section. This indicates that the integration is working as expected and that Pabbly Connect is successfully receiving data from WordPress.
5. Adding Sendinblue Action to Create Contact
With the trigger successfully set up, the next step is to add an action in Pabbly Connect to create a contact in Sendinblue. Select Sendinblue as the action application and choose ‘Create Contact’ as the action event. This setup will allow you to automatically add the new user details to your Sendinblue contact list.
To connect to Sendinblue, you will need to provide your API key. You can find this in your Sendinblue account under SMTP and API settings. After entering the API key in Pabbly Connect, select the list where you want to add the contacts. Map the fields from the WordPress trigger to the corresponding fields in Sendinblue, such as email, first name, and last name.
Once everything is set up, click on the ‘Save and Send Test Request’ button. If successful, you should see the new contact added to your Sendinblue list. This automation will now run seamlessly, adding new WordPress users to your Sendinblue contacts automatically.
By using Pabbly Connect, you can easily automate the process of adding new WordPress users to your Sendinblue contact list. This integration not only saves time but also ensures your email marketing efforts are streamlined and effective. Set it up once, and let Pabbly Connect handle the rest!
