Learn how to enroll Thinkific users automatically with Razorpay payments using Pabbly Connect in this detailed tutorial. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
1. Accessing Pabbly Connect for Razorpay and Thinkific Integration
To begin the integration process between Razorpay and Thinkific, you first need to access Pabbly Connect. This platform allows you to automate workflows without any coding skills.
Visit the Pabbly website and sign in to your account. If you are a new user, you can sign up for free. Once logged in, navigate to the Pabbly Connect dashboard, where you can manage your workflows.
2. Creating an Automation Workflow in Pabbly Connect
In this step, you will create a new automation workflow that connects Razorpay and Thinkific using Pabbly Connect. Start by selecting the Razorpay automation option and click on ‘Create Now’.
- Choose Razorpay as your trigger application.
- Set the trigger event to ‘Payment Captured’.
- Connect your Razorpay account by providing the required API keys.
Once you set up the trigger, the next step is to define the action that will occur in Thinkific when a payment is captured. This is where Pabbly Connect plays a crucial role in automating the process.
3. Setting Up Webhook in Razorpay
To establish the connection, you need to set up a webhook in your Razorpay account. This webhook will inform Pabbly Connect whenever a payment is successfully captured.
Open your Razorpay account and navigate to the ‘Webhooks’ section. Here, you will need to create a new webhook by entering the webhook URL provided by Pabbly Connect. Ensure you select the event for ‘Payment Captured’ to trigger the workflow.
4. Enrolling the User in Thinkific
After setting up the webhook, the next step is to enroll the user in Thinkific. In your Pabbly Connect workflow, select Thinkific as your action application.
- Choose the action event as ‘Create User’.
- Map the fields from Razorpay to Thinkific, such as email and name.
- Test the integration to ensure the user is enrolled successfully.
This step is vital as it automates the user enrollment process in Thinkific based on the payment captured through Razorpay, showcasing the efficiency of Pabbly Connect.
5. Finalizing and Testing the Integration
Once you have configured both Razorpay and Thinkific in your workflow, it’s time to finalize and test the integration. Ensure that all fields are correctly mapped and that the webhook is active.
Perform a test payment through Razorpay and check if the user is automatically enrolled in Thinkific. This test will confirm that Pabbly Connect is functioning as intended and that the integration is seamless.
Integrating Razorpay with Thinkific using Pabbly Connect allows for seamless user enrollment based on payment processing. This automation saves time and reduces manual effort, enhancing your online course management.
