Learn how to integrate Razorpay with GetResponse using Pabbly Connect to automate your payment processes and customer management. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To integrate Razorpay with GetResponse, start by accessing Pabbly Connect. This platform allows you to automate and streamline your workflows seamlessly. You can sign up for a free account or log into your existing one at the official Pabbly Connect website.
Once logged in, you will see the dashboard where you can create workflows. Click on the ‘Create Workflow’ button to begin setting up your integration. This will set the stage for connecting Razorpay and GetResponse through Pabbly Connect.
After accessing Pabbly Connect, you need to create a new workflow. Click on the ‘Create Workflow’ button and name it, for example, ‘Create GetResponse Contact on Razorpay Payment’. Organizing your workflows into folders can help keep your projects manageable.
- Select a folder for better organization.
- Learn how to create new folders if needed.
After naming your workflow and selecting the folder, you will be prompted to set a trigger. This is a crucial step where you define what will initiate the workflow in Pabbly Connect.
3. Setting Up the Trigger with Razorpay
The next step is to set up the trigger application, which will be Razorpay. Select Razorpay as your trigger application and choose the trigger event as ‘Payment Captured’. This event will activate the workflow whenever a payment is made.
Once you select the trigger event, Pabbly Connect will provide you with a webhook URL. This URL is essential for connecting Razorpay with Pabbly Connect. Copy this URL to use it in your Razorpay account settings.
- Select Razorpay as the trigger application.
- Choose ‘Payment Captured’ as the trigger event.
Now, navigate to your Razorpay account to set up the webhook with the URL you just copied. This step is vital for ensuring that Razorpay communicates with Pabbly Connect correctly.
4. Configuring the Webhook in Razorpay
Log into your Razorpay account and navigate to the ‘Account and Settings’ section. Here, select ‘Website and App Settings’ and then ‘Webhooks’. Click on the ‘Add New Webhook’ button to create a new webhook.
Paste the webhook URL from Pabbly Connect into the provided field. Then, select the event as ‘Payment Captured’ to ensure that Razorpay sends data to Pabbly Connect whenever a payment is made. After saving the webhook, Razorpay will be successfully connected with Pabbly Connect.
Navigate to ‘Account and Settings’ in Razorpay. Select ‘Website and App Settings’ then ‘Webhooks’. Click ‘Add New Webhook’ and paste the copied URL.
Once the webhook is configured, return to Pabbly Connect to test if the webhook is functioning correctly.
5. Adding a Contact in GetResponse
With the webhook successfully connected, the next step is to add a contact in GetResponse whenever a payment is captured. In Pabbly Connect, select GetResponse as your action application and choose the action event as ‘Create Contact’.
You will need to connect your GetResponse account to Pabbly Connect by providing your API key. This key can be generated from your GetResponse account settings. Once connected, you can map the data from Razorpay to GetResponse, ensuring that customer details are transferred accurately.
Select GetResponse as the action application. Choose ‘Create Contact’ as the action event. Map fields from Razorpay to GetResponse for accurate data transfer.
After mapping the necessary fields, you can test the integration by making a test payment through Razorpay. This will confirm that contacts are being created in GetResponse as expected via Pabbly Connect.
Integrating Razorpay with GetResponse using Pabbly Connect allows businesses to automate customer management seamlessly. By following the steps outlined, you can ensure that every payment captured leads to a new contact in your GetResponse account, enhancing your customer engagement and follow-up processes.
