Learn how to automate adding registrants to your workshop with Razorpay and Zoom integration using Pabbly Connect. Follow our detailed guide for seamless setup. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To begin the integration process, you need to access Pabbly Connect. Start by logging into your Pabbly Connect account. Once logged in, you will be on the dashboard where you can create a new workflow.
Click on the ‘Create Workflow’ button. Enter a name for your workflow, such as ‘Razorpay to Zoom Integration’. This workflow will help automate the process of adding registrants to your Zoom workshop when payment is confirmed through Razorpay.
2. Configuring Razorpay Trigger in Pabbly Connect
After setting up your workflow, the next step involves configuring the Razorpay trigger. In your workflow, select Razorpay from the list of applications. Choose the trigger event as ‘Payment Captured’. This event will initiate the workflow whenever a payment is successfully processed. using Pabbly Connect
  • Select Razorpay as the application.
  • Choose the event ‘Payment Captured’.
  • Connect your Razorpay account by following the prompts.
Once connected, you will need to test the trigger to ensure it captures payment data correctly. This step is crucial as it verifies that Pabbly Connect can receive data from Razorpay.
3. Adding Zoom Action in Pabbly Connect
With the Razorpay trigger set up, the next step is to add an action for Zoom. In your Pabbly Connect workflow, select Zoom as the application for the action step. Choose the action event as ‘Add Registrant’. This action will automatically register a participant to your Zoom workshop once a payment is received. using Pabbly Connect
Connect your Zoom account to Pabbly Connect. You will be prompted to authorize Pabbly Connect to access your Zoom account. Once authorized, fill in the required fields, including the participant’s email, first name, and last name. These fields will be populated with data from the Razorpay payment details.
4. Testing and Finalizing the Integration
After configuring the Zoom action, it’s time to test the entire workflow. Trigger a test payment in Razorpay to see if the registrant is added to your Zoom workshop. Pabbly Connect will show you the data being sent to Zoom, allowing you to confirm that everything is working correctly. using Pabbly Connect
  • Perform a test payment in Razorpay.
  • Check if the registrant appears in your Zoom account.
  • Review the data sent by Pabbly Connect for accuracy.
If the test is successful, you can turn on your workflow. This means that every time a payment is captured in Razorpay, Pabbly Connect will automatically add the registrant to your Zoom workshop without any manual intervention.
5. Conclusion
Integrating Razorpay and Zoom through Pabbly Connect allows you to automate the registration process for your workshops. By following the steps outlined, you can ensure a seamless experience for both you and your participants. This integration saves time and reduces manual errors, enhancing overall efficiency.
