Learn how to integrate PayKickstart with HubSpot using Pabbly Connect to automate contact creation seamlessly. Follow this detailed tutorial for easy setup. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To begin the integration process, access Pabbly Connect by typing Pabbly.com in your browser. This platform facilitates the connection between PayKickstart and HubSpot seamlessly.
Once on the Pabbly website, hover over the ‘Products’ tab and select ‘Connect.’ Click on ‘Sign In’ to log into your account. If you are new, you can create a free account in just a couple of minutes. Pabbly Connect allows you to try out the integration for free, making it an excellent choice for automation.
After logging in, click on the ‘Create Workflow’ button located at the top right corner of the dashboard. This opens a dialog box where you can name your workflow. Name it ‘PayKickstart to HubSpot’ and click on ‘Create’ to proceed.
  • Select ‘PayKickstart’ as the trigger app.
  • Choose the trigger event as ‘Subscription Created.’
  • Click on ‘Save & Send Test Request’ to confirm the setup.
This setup allows Pabbly Connect to listen for new subscriptions created in PayKickstart, which will trigger the next steps in the workflow.
3. Configure PayKickstart Integration in Pabbly Connect
Next, navigate to your PayKickstart account and select the product you want to integrate. Click on ‘Edit’ for your chosen product, and scroll down to find the ‘Integration’ section.
Enable the integration by clicking on the toggle. Once enabled, you will need to enter the IPN URL provided by Pabbly Connect. Copy the webhook URL from Pabbly and paste it into the IPN URL field in PayKickstart. Set the event to ‘Subscription Created’ and save your changes.
This configuration ensures that any new subscription will automatically send data to Pabbly Connect, which will then process it for HubSpot integration.
4. Map Data to HubSpot for Contact Creation
With the integration set up, it’s time to map the data to HubSpot. In Pabbly Connect, click the plus icon to add HubSpot as the next application in your workflow. Select ‘Create a Contact’ as the action event.
  • Connect to HubSpot by entering your API key.
  • Map the fields from PayKickstart to the corresponding fields in HubSpot, such as email, first name, and last name.
  • Save the configuration and send a test request to verify the connection.
This step is crucial as it allows Pabbly Connect to create new contacts in HubSpot automatically whenever a new subscription is made in PayKickstart.
5. Test the Integration and Confirm Success
To ensure everything is working correctly, perform a test by creating a new subscription in PayKickstart. Fill in the required details and complete the purchase.
After the subscription is created, return to Pabbly Connect and check if the data has been captured. You should see the details of the new subscription, confirming that the integration is functioning properly.
Finally, check your HubSpot account to see if the new contact has been created. If the contact appears, the integration between PayKickstart and HubSpot via Pabbly Connect is successful, allowing for seamless automation of your workflows.
Integrating PayKickstart with HubSpot using Pabbly Connect automates contact creation effectively. This guide provides a step-by-step approach to setting up the integration, ensuring your workflows are streamlined and efficient.
