Learn how to integrate PayKickstart with Autopilot using Pabbly Connect. This step-by-step tutorial covers all necessary actions for seamless automation. Follow this definitive guide to creating powerful automated workflows with straightforward, efficiency-focused solutions that save valuable time.
To begin the integration process, access Pabbly Connect by visiting the official website. Type Pabbly.com in your browser and hit enter. Once on the website, hover over the ‘Products’ tab and select ‘Connect’ from the dropdown menu.
Next, click on the ‘Sign In’ button to access your dashboard. If you don’t have an account, you can create a free account in just two minutes. Pabbly Connect allows you to try this integration absolutely free, making it easy to set up your automation.
After accessing your Pabbly Connect dashboard, scroll down and click on ‘Access Now’. In the top right corner, you will find a button labeled ‘Create Workflow’. Click on it, and a dialog box will appear asking for a workflow name.
- Name your workflow, for example, ‘PayKickstart to Autopilot’.
- Select ‘PayKickstart’ as the app in the trigger section.
- Choose the trigger event as ‘Fulfillment Order Received’.
Once you have configured these settings, click on ‘Create’. This action sets up the trigger that will initiate the workflow whenever a new order is fulfilled in PayKickstart.
3. Setting Up PayKickstart Integration
To integrate PayKickstart with Pabbly Connect, navigate to your PayKickstart account and click on the ‘Campaigns’ tab. Select the product you want to integrate and click on ‘Edit’. Scroll down to the ‘Integrations’ section and click on it.
In the IPN URL field, paste the webhook URL you copied from Pabbly Connect. Set the event as ‘Fulfillment Order Received’ and click on ‘Save’. This step ensures that any new order fulfillment in PayKickstart will trigger the webhook, sending data to Pabbly Connect.
4. Capturing Data in Pabbly Connect
With the integration set, return to Pabbly Connect and click on the ‘Capture Webhook Response’ button. This action allows Pabbly Connect to wait for data from PayKickstart. To test this, change the status of an order in PayKickstart to ‘Order Received’.
After updating the order status, check Pabbly Connect to see if it captured the data successfully. You should see the details of the customer, including billing address and email. This confirms that the integration is working correctly and that data is flowing from PayKickstart to Pabbly Connect.
5. Adding Contact in Autopilot via Pabbly Connect
Now, it’s time to add the captured data to Autopilot. In Pabbly Connect, click on the plus button to add an action step. Select ‘Autopilot’ as the app and choose the action event ‘Add/Update Contact’. Click on ‘Connect with Autopilot’ to proceed.
You will need to enter your Autopilot API key, which can be found in the Autopilot settings. After entering the API key, click on ‘Save’. Next, map the fields from the captured data to the Autopilot contact fields such as email, first name, and last name. Once all fields are mapped, click on ‘Save and Send Test Request’.
Check your Autopilot account to confirm that the contact has been added successfully. This final step demonstrates how Pabbly Connect seamlessly integrates PayKickstart with Autopilot, allowing for automated contact management.
In this tutorial, we explored how to integrate PayKickstart with Autopilot using Pabbly Connect. By following the steps outlined, you can automate your workflows efficiently and enhance your marketing efforts.
