Learn how to integrate PayKickstart with Slack using Pabbly Connect. This tutorial provides a detailed step-by-step process for automating notifications for cancelled subscriptions. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To integrate PayKickstart and Slack, first, access Pabbly Connect. Simply type ‘Pabbly.com’ in your browser and press enter. Once on the website, hover over the ‘Products’ menu and select ‘Connect’ to begin the integration process.
After clicking on ‘Connect,’ you will need to sign in or create a new account. Pabbly Connect allows you to set up your automation easily without any coding skills. You can create a free account to explore its features and try out this integration.
Once logged into Pabbly Connect, you will see the dashboard. Here, click on the ‘Create Workflow’ button at the top right corner. A dialog box will appear asking for a name for your workflow; enter ‘PayKickstart to Slack’ and click ‘Create’ to proceed.
In the trigger window that appears, select ‘PayKickstart’ as the app. For the trigger event, choose ‘Subscription Cancelled.’ This trigger will activate the workflow whenever a subscription is cancelled in PayKickstart.
3. Setting Up PayKickstart for Integration
To link PayKickstart with Pabbly Connect, navigate to your PayKickstart account. Click on ‘Campaigns’ and select the product you wish to integrate. Click ‘Edit’ and scroll down to the ‘Integrations’ section. Here, you will find an option to add the IPN URL.
Copy the webhook URL provided by Pabbly Connect and paste it into the IPN URL field in PayKickstart. Set the event to ‘Subscription Cancelled’ and save your changes. This step ensures that whenever a subscription is cancelled, the information is sent to Pabbly Connect.
4. Capturing Data from PayKickstart
After saving your integration settings in PayKickstart, return to Pabbly Connect and click on ‘Capture Hook Response.’ This action allows Pabbly Connect to listen for incoming data from PayKickstart. To test this, cancel a subscription in PayKickstart.
Once you cancel a subscription, Pabbly Connect will capture the data. You should see details such as the name, email, and cancellation reason in the captured data. This confirms that the integration is functioning correctly.
5. Sending a Message to Slack
Now that Pabbly Connect has captured the data, it’s time to send a message to Slack. Click the plus button in your workflow and choose ‘Slack’ as the app. Select ‘Send Channel Message without Image’ as the action event.
Connect your Slack account by clicking ‘Connect with Slack’ and allow the necessary permissions. Once connected, choose the channel where you want to send the message. You can create a new channel specifically for PayKickstart cancellations or use an existing one.
- Enter the message details, including the subscriber’s name and cancellation reason.
- Set the message type as plain text.
- Click ‘Save and Send Test Request’ to finalize the setup.
After sending the test message, check your Slack channel to confirm that the cancellation notification was received. This integration allows you to automate notifications seamlessly using Pabbly Connect.
In this tutorial, we explored how to integrate PayKickstart with Slack using Pabbly Connect. By following the step-by-step process, you can automate notifications for cancelled subscriptions, enhancing your workflow efficiency.
