Learn how to automate email notifications with Pabbly Connect when Outscraper tasks are completed. Step-by-step guide to integrate Gmail and Outscraper. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
1. Setting Up Pabbly Connect for Email Notifications
To begin the integration process, first access Pabbly Connect. This platform will allow you to automate sending email notifications when a task is completed in Outscraper. Start by signing in to your Pabbly account and navigating to the Pabbly Connect dashboard.
Once you are on the dashboard, click on the big blue button labeled ‘Create Workflow’. This will lead you to a blank workflow setup page where you can name your workflow. For this tutorial, name it ‘Send Email When Outscraper Task is Completed’. After naming your workflow, click on the ‘Create’ button to proceed.
2. Choosing Outscraper as the Trigger Application
In this step, you will set Outscraper as the trigger application in Pabbly Connect. The trigger event will be set to ‘On Task Complete’, which means the workflow will activate whenever a task in Outscraper is completed. Select Outscraper from the list of applications and choose the trigger event accordingly.
After selecting the trigger event, you will be provided with a webhook URL. This URL is crucial for connecting Outscraper with Pabbly Connect. Copy this URL and head over to your Outscraper account. Navigate to the Integrations section and paste the webhook URL into the designated field. Then, save the changes to establish the connection.
3. Creating a Task in Outscraper
Now that the webhook is set up, you need to create a task in Outscraper to scrape the desired data. In Outscraper, enter the URL of the website from which you want to scrape emails or contacts. Make sure to choose the output format, such as JSON or Google Sheets, based on your requirements.
After entering the necessary details, click on ‘Get Data’ to initiate the scraping process. The task will take some time to complete, typically around 10 to 20 minutes. Once the task is finished, Pabbly Connect will receive the data response, which will be displayed on your workflow page.
  • Enter the URL of the website to scrape.
  • Select the output format (JSON or Google Sheets).
  • Click ‘Get Data’ to start the scraping process.
Once the data is received, you will see the status as ‘Success’ in Pabbly Connect. This indicates that the information has been successfully scraped and is ready for the next step.
4. Setting Up Gmail as the Action Application
In this section, you will configure Gmail as the action application in Pabbly Connect. The action event will be set to ‘Send Email’, which allows you to notify your team members about the completed task in Outscraper. Select Gmail from the list of applications and choose the action event.
To connect Gmail with Pabbly Connect, click on ‘Connect’ and then choose ‘Add New Connection’. Since Gmail is a Google application, you will need to authorize it by signing into your Google account and granting the necessary permissions. Once connected, fill in the required fields such as recipient email address, sender’s name, subject, and email content.
  • Enter the recipient’s email address.
  • Fill in the sender’s name and subject of the email.
  • Compose the email content, including any relevant links or data.
After filling out all the necessary fields, click on ‘Save and Send Test Request’. This will send a test email to the recipient you specified, confirming that the integration is working correctly. You will see a response indicating that the email was sent successfully.
5. Conclusion
In this tutorial, we demonstrated how to automate email notifications using Pabbly Connect when tasks are completed in Outscraper. By following the steps outlined, you can easily integrate Outscraper with Gmail to streamline your workflow and keep your team informed. This process not only saves time but also ensures that important updates are communicated promptly.
Utilizing Pabbly Connect for this integration can significantly enhance your productivity and efficiency. Now, you can focus on other important tasks while receiving instant notifications about your Outscraper activities.
