Learn how to integrate Ora with Google Sheets using Pabbly Connect. Follow this detailed tutorial for seamless task management and data automation. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Introduction to Pabbly Connect for Integration
In this tutorial, we will explore how to use Pabbly Connect to integrate Ora with Google Sheets. This integration allows you to automatically add new tasks from your Ora account to a designated Google Sheet. The process is straightforward and doesn’t require any technical expertise.
To start, navigate to the Pabbly Connect website. If you don’t have an account, you can easily sign up for free. Once signed in, you can access the integration features that will help you connect Ora and Google Sheets seamlessly.
2. Setting Up Pabbly Connect for Ora and Google Sheets
To set up the integration, click on the “Create Workflow” button in Pabbly Connect. You will be prompted to name your workflow. For this example, we will name it ‘Ora to Google Sheets’ to keep it relevant.
  • Select the app as Ora in the trigger window.
  • Choose the trigger event as New Task.
  • Click on Connect and authorize your Ora account.
After connecting, you will need to select the specific project and list from your Ora account. This ensures that the tasks you create will be sent to the correct Google Sheet.
3. Creating a New Task in Ora
Now that you have set up the connection, navigate to your Ora account and create a new task. For instance, you can name the task ‘Upgrade Windows 10’ and provide a description such as ‘Windows 11 is here.’ After adding the task, you will need to save it.
Once the task is created, go back to Pabbly Connect and click on “Save and Send Test Request.” This action fetches the details of the newly created task from Ora. Ensure that the task title and description are correctly displayed in the test results.
4. Setting Up Google Sheets to Receive Data
Next, you will need to set up a Google Sheet to receive the data. Create a new Google Sheet and name it ‘Ora to Google Sheets.’ Set up the columns as follows: Time, Title, and Description. This structure will help organize the task data effectively.
  • Select Google Sheets as the action app in Pabbly Connect.
  • Choose the action event as Add New Row.
  • Connect your Google account and select the sheet you created.
Once connected, map the fields from the Ora task to the corresponding columns in Google Sheets. This ensures that the task details are accurately transferred whenever a new task is created in Ora.
5. Finalizing the Integration
After mapping the fields, click on “Save and Send Test Request” in Pabbly Connect. This action will send the task details to your Google Sheet. You should see the new task reflected in the sheet with its title and description.
Once the integration is successfully set up, every time you create a new task in Ora, it will automatically populate in your Google Sheet without any further action required. This automation saves time and keeps your task management organized.
Using Pabbly Connect to integrate Ora with Google Sheets streamlines task management and data organization. By following this tutorial, you can automate the process of adding new tasks to your Google Sheet effortlessly. This integration enhances productivity and ensures that you never miss important task updates.
