Learn how to instantly add Moosend subscribers from new Shopify customers using Pabbly Connect. Follow our detailed tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
1. Setting Up Pabbly Connect for Shopify and Moosend Integration
To begin integrating Moosend with Shopify, first access Pabbly Connect. This platform allows you to automate workflows between various applications, including Shopify and Moosend.
Log into your Pabbly Connect account or create a new one if you haven’t already. Once logged in, navigate to the dashboard where you can initiate the integration process.
In this step, you will create a new workflow to connect Shopify with Moosend. Click on the ‘Create Workflow’ button in Pabbly Connect. You will be prompted to name your workflow.
  • Name your workflow, for example, ‘Shopify to Moosend Integration’.
  • Select Shopify as the trigger application.
  • Choose the trigger event as ‘New Customer’.
After setting up the trigger, proceed to connect your Shopify account by following the prompts in Pabbly Connect. You will need to authenticate your Shopify account by granting necessary permissions.
3. Configuring Moosend as the Action in Pabbly Connect
Next, you need to set up Moosend as the action application in your workflow. Click on ‘Add Action’ in Pabbly Connect and select Moosend.
  • Choose the action event as ‘Add Subscriber’.
  • Connect your Moosend account by following the authentication steps.
  • Map the fields from Shopify to Moosend, such as email and name.
Ensure all mapped fields are correctly filled to facilitate smooth data transfer. This step is crucial for the integration to function properly.
4. Testing the Integration in Pabbly Connect
Once you’ve configured both Shopify and Moosend, it’s time to test the integration. In Pabbly Connect, you will find an option to test your workflow.
Click on ‘Test Workflow’ to simulate the process. If successful, you should see a new subscriber added to your Moosend account based on the test data from Shopify. This confirms that the integration is working as intended.
5. Activating the Workflow in Pabbly Connect
After testing, the final step is to activate your workflow in Pabbly Connect. This ensures that every time a new customer is created in Shopify, they will automatically be added as a subscriber in Moosend.
Simply toggle the switch to activate your workflow. Now, your integration is live, and you can start enjoying the benefits of automated email marketing through Moosend based on your Shopify customer data.
In this tutorial, we explored how to use Pabbly Connect to seamlessly integrate Moosend with Shopify. By following these steps, you can automate the process of adding new subscribers, enhancing your email marketing efforts effortlessly.
