Learn how to integrate Marquiz and MailerLite using Pabbly Connect. Follow this step-by-step guide to automate subscriber creation effortlessly. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To begin integrating Marquiz and MailerLite, first access Pabbly Connect. Open your preferred web browser and search for Pabbly Connect to reach the platform’s landing page.
On the landing page, you will see options to either sign in or sign up for free. If you are a new user, click on ‘Sign Up for Free’ to create an account. Existing users should click ‘Sign In’ to access their dashboards. After logging in, select ‘Access Now’ for Pabbly Connect to start the integration process.
Once you’re in Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow and choose a folder for saving it. Name your workflow something descriptive, like ‘Automatically Create MailerLite Subscribers on Marquiz Form Submission’.
After naming your workflow, click on ‘Create’. You will be directed to the workflow window where you will set up your trigger and action. The trigger is the event that starts the workflow, while the action is what happens in response. Here, you will select Marquiz as your trigger application.
- Click on the trigger application dropdown.
- Search for Marquiz and select it.
- Choose ‘New Leads’ as the trigger event.
Now, Pabbly Connect will provide you with a webhook URL. Copy this URL as it will be used to connect Marquiz with your workflow.
3. Connecting Marquiz to Pabbly Connect
Next, you need to connect Marquiz to your Pabbly Connect workflow. Log into your Marquiz account and navigate to the quiz you want to edit. Click on ‘Edit’ to access the quiz editor. In the left sidebar, find and click on ‘Integrations’.
Scroll down to find the ‘Webhooks’ option and select it. Click on ‘Add Webhook’, then paste the webhook URL you copied from Pabbly Connect. After pasting the URL, click ‘Done’ to save the integration.
- Ensure you publish the changes in Marquiz.
- Return to your Pabbly Connect workflow and check for a webhook response.
To test the connection, you need to submit a test entry through your Marquiz form. This will confirm that the webhook is working correctly.
4. Creating a Subscriber in MailerLite via Pabbly Connect
After successfully capturing the webhook response from Marquiz, the next step in Pabbly Connect is to set up the action to create a subscriber in MailerLite. Select MailerLite as your action application.
Choose ‘Create or Update Subscriber’ as the action event. If you have an existing connection with MailerLite, you can select it; otherwise, click on ‘Add New Connection’. You will be prompted to enter your API token from MailerLite.
Log into your MailerLite account to generate an API token. Copy the token and paste it into Pabbly Connect. Map the subscriber’s email and other details from the webhook response.
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’ to finalize the integration. This action will create a new subscriber in your MailerLite account.
5. Testing the Integration and Finalizing the Workflow
To ensure everything is working correctly, perform a test submission through your Marquiz form again. Fill out the form with different dummy details and submit it. This will send new data to Pabbly Connect.
Return to your Pabbly Connect workflow and check if the new subscriber has been created in MailerLite. Refresh the subscribers’ page in MailerLite to verify the new entry appears. You should see the new subscriber listed with the details you entered.
Confirm that the subscriber’s details are accurate. Repeat the process if necessary to ensure reliability.
With this, you have successfully integrated Marquiz and MailerLite using Pabbly Connect. This automation will streamline your subscriber management and enhance your marketing efforts.
In this tutorial, we covered how to integrate Marquiz and MailerLite using Pabbly Connect. By following these steps, you can automate subscriber creation effortlessly, enhancing your marketing efforts and improving customer engagement.
