Learn how to integrate Mailjet with Elementor using Pabbly Connect for automated subscriber management. Follow our detailed tutorial for seamless email marketing integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Setting Up Pabbly Connect for Mailjet Integration
To begin integrating Mailjet with Elementor, you will first need to set up Pabbly Connect. This platform allows you to automate tasks between different applications seamlessly. Start by creating a free Pabbly Connect account, which can be done quickly through the sign-up option on their website.
Once you are logged in, navigate to the Pabbly Connect dashboard. Click on the blue button labeled ‘Create Workflow’ to start your automation. You will need to name your workflow, such as ‘Create Mailjet Subscriber from Elementor Form Submission,’ and select a folder to save it in.
2. Configuring the Trigger Event in Elementor
The next step is to configure the trigger event for your workflow. In Pabbly Connect, you will select Elementor as your application and choose the trigger event as ‘New Form Submission.’ This means that every time a new form is submitted through Elementor, it will initiate the workflow.
- Select ‘New Form Submission’ as the trigger event.
- Copy the provided webhook URL from Pabbly Connect.
- Paste this URL into the Elementor form settings under ‘Actions After Submit’.
After pasting the webhook URL into Elementor, click on the update button to save your changes. This setup ensures that every submission from the Elementor form is sent to Pabbly Connect, ready for processing.
3. Testing the Elementor Form Submission
Now that your webhook is set up, it’s time to test the integration. You will need to submit a test entry through your Elementor form. Fill in the form with dummy data such as a first name, last name, and email address, then click on the submit button.
Once you submit the form, return to Pabbly Connect to see if the test data has been captured successfully. You should see the same data reflected in the webhook response, confirming that the connection between Elementor and Pabbly Connect is functioning correctly.
4. Integrating Mailjet with Pabbly Connect
With the Elementor form submission successfully captured, the next step is to integrate Mailjet. In Pabbly Connect, select Mailjet as your action application and choose the action event as ‘Subscribe Contact to Mailjet List.’ This action will create a subscriber in your Mailjet account based on the form submission data.
- Connect your Mailjet account by entering your API key and secret key.
- Select the appropriate contact list in Mailjet for new subscribers.
- Map the fields from the Elementor form submission to the corresponding fields in Mailjet.
After mapping the necessary fields, click on the save button to complete the integration. This setup allows new subscribers to be added to your Mailjet list automatically whenever someone submits the Elementor form.
After setting up the Mailjet integration, it’s essential to finalize and test the entire workflow. Go back to your Elementor form and submit another test entry to ensure that the data flows correctly from Elementor through Pabbly Connect to Mailjet.
Once you submit the form, check your Mailjet dashboard to verify that the new subscriber has been added successfully. You should see the new entry reflecting the data you submitted through Elementor. This confirms that your integration is complete and functioning as intended.
In this tutorial, you learned how to integrate Mailjet with Elementor using Pabbly Connect. By following these steps, you can automate the process of adding subscribers to your Mailjet list, making your email marketing efforts more efficient. Enjoy the benefits of seamless integration and automated workflows!
