Learn how to integrate MailerLite with Razorpay payments and send updates via WhatsApp using Pabbly Connect in this detailed tutorial. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To integrate MailerLite with Razorpay and WhatsApp, you first need to access Pabbly Connect. This platform allows seamless automation between the applications without requiring a technical background. Start by visiting the Pabbly Connect website and signing up for a free account.
Once logged in, you will find the dashboard where you can create workflows. Click on ‘Create Workflow’ and name it appropriately, such as ‘Razorpay to MailerLite and WhatsApp’. This indicates the data flow that will occur between Razorpay, MailerLite, and WhatsApp through Pabbly Connect.
Setting Up Webhook for Razorpay Payments
To initiate the integration, you need to set up a webhook in your Razorpay account. This webhook will send payment data to Pabbly Connect. Navigate to the Razorpay dashboard and go to the settings section where you can find the webhooks option.
Click on ‘Add Webhook’ and paste the webhook URL provided by Pabbly Connect. Ensure that the active event is set to ‘Payment Captured’. This setup will allow Razorpay to communicate with Pabbly Connect whenever a payment is successfully made.
- Go to Razorpay settings and select webhooks.
- Click on ‘Add Webhook’ and paste the Pabbly Connect webhook URL.
- Set the active event to ‘Payment Captured’.
After setting up the webhook, you can test it by making a dummy payment. This will confirm that Razorpay is correctly sending the payment data to Pabbly Connect.
Adding Subscriber to MailerLite
Once the webhook is successfully capturing payments, the next step is to add the subscriber to MailerLite. In the Pabbly Connect workflow, add an action step to connect with MailerLite. Choose the action event as ‘Add Subscriber’ and connect your MailerLite account using the API key.
Map the necessary fields such as email, first name, and last name from the Razorpay data. This ensures that each successful payment results in a new subscriber being added to your MailerLite list. The integration through Pabbly Connect simplifies this process by automatically pulling in the data.
- Select ‘Add Subscriber’ as the action event in Pabbly Connect.
- Connect your MailerLite account using the API key.
- Map the email and name fields from Razorpay data.
This setup allows you to efficiently manage your subscribers based on payment activities, enhancing your email marketing efforts.
Sending WhatsApp Updates to Customers
After successfully adding a subscriber to MailerLite, the final step is to send a WhatsApp message to the customer. In your Pabbly Connect workflow, add another action step to connect with WhatsApp using the Wati app. Choose the action event as ‘Send Template Message’.
You will need to configure the message template, including the customer’s name and order details. Make sure to map the WhatsApp number and include the appropriate country code. This message will confirm the order and provide contact information for any inquiries, showcasing the power of Pabbly Connect in automating customer communication.
Add an action step for WhatsApp using Wati. Select ‘Send Template Message’ as the action event. Map the WhatsApp number and country code in the template.
This integration ensures that every customer receives timely updates, enhancing their post-purchase experience.
In summary, integrating MailerLite with Razorpay payments and sending updates via WhatsApp using Pabbly Connect streamlines your marketing efforts. This process allows for efficient subscriber management and enhances customer communication. By following these steps, you can automate your workflows and improve customer satisfaction.
