Learn how to seamlessly integrate MailChimp with Zendesk Sell using Pabbly Connect. Follow this step-by-step tutorial for effortless automation. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Accessing Pabbly Connect for MailChimp and Zendesk Integration
To start integrating MailChimp with Zendesk Sell, you need to access Pabbly Connect. First, type ‘Pabbly.com’ in your browser and press enter. This will take you to the Pabbly homepage where you can find the option for Pabbly Connect.
Once on the website, navigate to the products section and click on the option labeled ‘Connect’. You will then need to sign in or create an account if you don’t have one. Pabbly Connect allows you to set up integrations without any coding skills, making it user-friendly for everyone.
After signing in to Pabbly Connect, you will be directed to the dashboard. Click on the ‘Create Workflow’ button located at the top right corner. A dialog box will appear asking you to name your workflow; you can name it ‘MailChimp to Zendesk’.
- Click on ‘Create’ to initiate the workflow.
- Select ‘MailChimp’ as the app for the trigger event.
- Choose ‘New Subscriber’ as the trigger event.
This setup allows Pabbly Connect to capture data from MailChimp whenever a new subscriber is added, facilitating the integration with Zendesk Sell.
3. Configuring Webhooks in MailChimp
To ensure data is sent from MailChimp to Pabbly Connect, you need to configure a webhook. Go to your MailChimp account, navigate to the ‘Audience’ section, and select ‘All Contacts’. From there, click on ‘Settings’ and then ‘Webhooks’.
- Click on ‘Create New Webhook’.
- Paste the webhook URL provided by Pabbly Connect into the appropriate field.
- Select the events for which you want to receive data, ensuring ‘Subscribe’ is checked.
Once saved, this webhook will allow Pabbly Connect to receive data whenever a new subscriber is added in MailChimp, thus enabling the integration.
4. Creating a Lead in Zendesk Sell
With the webhook configured, the next step is to create a lead in Zendesk Sell using the data captured by Pabbly Connect. Go back to your Pabbly Connect dashboard and click on the plus button to add an action step.
Select ‘Zendesk Sell’ as the app. Choose ‘Create Lead’ as the action event. Connect your Zendesk Sell account by authorizing Pabbly Connect.
Once connected, you can map the fields from MailChimp to Zendesk Sell, ensuring that data such as names and email addresses are correctly transferred to create a new lead.
5. Testing the Integration
After setting everything up in Pabbly Connect, it’s essential to test the integration. You can do this by adding a new subscriber in MailChimp. Ensure that the information is captured by Pabbly Connect and that a new lead is created in Zendesk Sell.
For example, if you add a subscriber named ‘Tommy Green’, you should see this lead appear in your Zendesk Sell account. This confirms that the integration between MailChimp and Zendesk Sell via Pabbly Connect is successful.
By following these steps, you can seamlessly automate your workflow between MailChimp and Zendesk Sell, enhancing your productivity without any coding skills.
In conclusion, integrating MailChimp with Zendesk Sell using Pabbly Connect streamlines your lead generation process. By following this detailed tutorial, you can automate data transfer effortlessly and improve your sales workflow.
