Learn how to integrate MailChimp with Razorpay using Pabbly Connect to automatically add members upon invoice payment. Follow our detailed tutorial for seamless integration. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To start integrating MailChimp with Razorpay, you first need to access Pabbly Connect. This platform serves as the bridge for connecting various applications seamlessly.
Visit the Pabbly website and create a free account. Once logged in, navigate to the Pabbly Connect dashboard to begin setting up your integration.
2. Setting Up Invoice Trigger in Razorpay
The next step involves configuring Razorpay to trigger events when an invoice is paid. This is crucial for ensuring that your MailChimp list updates automatically.
- Log into your Razorpay account.
- Go to the ‘Webhook’ section and create a new webhook.
- Set the event to trigger on ‘Invoice Paid’.
Once you have set the webhook, Razorpay will send a notification to Pabbly Connect every time an invoice is paid. This ensures that your MailChimp list remains up-to-date with new members automatically.
3. Configuring MailChimp Action in Pabbly Connect
After setting up Razorpay, the next step is to configure the MailChimp action in Pabbly Connect. This action will add a new member to your MailChimp list whenever an invoice is paid.
In your Pabbly Connect dashboard, select MailChimp as the application for the action step. Choose the action event as ‘Add Member’. You will need to authenticate your MailChimp account to allow Pabbly Connect to access it.
- Enter your MailChimp API key to connect Pabbly Connect with MailChimp.
- Select the audience list where you want new members to be added.
- Map the fields from Razorpay to MailChimp, such as email and name.
Completing these steps allows Pabbly Connect to automatically add new members to your MailChimp audience whenever an invoice is paid in Razorpay.
4. Testing the Integration of Razorpay and MailChimp
Once the configuration is complete, it’s essential to test the integration to ensure everything works as expected. Pabbly Connect offers a straightforward way to do this.
Trigger a test invoice payment in Razorpay and check if the member is added to your MailChimp list. If everything is set up correctly, you should see the new member appear in your MailChimp audience shortly after the test payment.
In case of any issues, revisit the mapping and configuration steps in Pabbly Connect to troubleshoot the problem. Ensure that all fields are mapped correctly and that the webhook is functioning properly.
5. Finalizing Your Integration with Pabbly Connect
After successful testing, your integration between Razorpay and MailChimp via Pabbly Connect is now live. This automation will save you time and ensure your marketing efforts are always up-to-date.
To finalize, monitor the integration for a few days to ensure everything is functioning smoothly. You can also explore additional features offered by Pabbly Connect for more automation possibilities.
With this setup, every time an invoice is paid in Razorpay, a new member will be automatically added to your MailChimp list, enhancing your marketing capabilities.
Integrating MailChimp with Razorpay using Pabbly Connect allows you to automate the process of adding new members upon invoice payment. This setup enhances efficiency and ensures your marketing lists are always current.
