Learn how to integrate Magic Bricks leads with Go High Level using Pabbly Connect through this step-by-step tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Magic Bricks leads with Go High Level, you first need to access Pabbly Connect. This platform allows seamless automation between different applications.
Visit the Pabbly Connect homepage. If you are a new user, click on ‘Sign Up Free’ to create an account. Existing users can simply click on ‘Sign In’. Once logged in, you will see the dashboard where you can manage your workflows.
After accessing Pabbly Connect, the next step is to create a workflow to automate the integration process. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
- Name your workflow, for example, ‘Magic Bricks Leads to Go High Level’.
- Select a folder to save your workflow.
- Click on the ‘Create’ button to finalize your workflow creation.
With your workflow created, you are now ready to set up the trigger and action for the integration process.
3. Setting Up Trigger with Magic Bricks
In this section, you will configure the trigger in Pabbly Connect to capture new leads from Magic Bricks. Select Magic Bricks as your trigger application and set the trigger event to ‘New Leads’.
Once the trigger is selected, you will receive a webhook URL. This URL needs to be configured in your Magic Bricks account. Contact your Magic Bricks account manager to add this webhook URL since the platform does not allow direct user interface configuration.
4. Configuring Action to Create Contacts in Go High Level
Now, set up the action step in Pabbly Connect. Select Go High Level as your action application and choose ‘Create Contact’ as the action event. This will allow new leads from Magic Bricks to be automatically added as contacts in your Go High Level account.
- Connect your Go High Level account to Pabbly Connect.
- Map the fields from your Magic Bricks lead to the corresponding fields in Go High Level.
- Click ‘Save and Send Test Request’ to verify the integration.
After successfully mapping the fields, you can check your Go High Level account to confirm that the new contact has been created.
To ensure that the integration works correctly, perform a test submission in Pabbly Connect. Capture the webhook response to see if the details from Magic Bricks are correctly passed to Go High Level.
Once the test is successful, you will see the new contact created in your Go High Level account. This confirms that your automation is functioning as intended, saving you time and effort in managing leads.
In this tutorial, we demonstrated how to integrate Magic Bricks leads with Go High Level using Pabbly Connect. This automation streamlines your lead management process, ensuring that no potential client is missed. By following these steps, you can enhance your real estate business efficiency and focus on closing deals.
