Learn how to automate Keep contact creation from Landing G form submissions using Pabbly Connect. Step-by-step tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Keep with Landing G, first access Pabbly Connect by visiting the Pabbly website. Once there, sign in to your account using the ‘Sign In’ option on the top right corner. If you’re new, you can sign up for free and get 100 tasks monthly.
After signing in, navigate to the Pabbly Connect dashboard. Here, you can create new workflows. Click on the ‘Create Workflow’ button, name your workflow (e.g., ‘Create Keep Contact on Landing G Form Submission’), and select the appropriate folder for organization.
2. Setting Up the Trigger with Landing G
In this section, we will set up the trigger in Pabbly Connect using Landing G. Select Landing G as your trigger application, and choose the event ‘New Lead’ as the trigger event. This will initiate the workflow whenever a new form is submitted.
  • Choose Landing G as the trigger application.
  • Select ‘New Lead’ as the trigger event.
Next, go to your Landing G account and edit the form settings. Under integrations, find the Webhook option and paste the URL copied from Pabbly Connect. Set the request method to POST and save the changes. This establishes a connection between Landing G and Pabbly Connect.
3. Testing the Webhook Response
After setting up the trigger, it’s time to test the connection. Submit a test entry through your Landing G form. This is crucial as it helps confirm that data is being sent to Pabbly Connect.
  • Fill out the form with dummy details.
  • Submit the form to trigger the webhook.
  • Check Pabbly Connect for the webhook response.
Once you submit the form, return to Pabbly Connect to see if the response has been captured. If successful, you will see the details from the form submission, confirming that Landing G is now connected through Pabbly Connect.
4. Setting Up the Action to Create Contacts in Keep
Now that the trigger is set, we will configure the action in Pabbly Connect to create a contact in Keep. Choose Keep as your action application and select ‘Create or Update Contact’ as the action event. This step enables the creation of new contacts automatically.
Connect your Keep account with Pabbly Connect by granting the necessary permissions. After connecting, map the fields from the previous response to the Keep contact fields. Ensure to use the email, name, and phone number from the webhook response.
5. Finalizing and Testing the Integration
After mapping the fields, click on ‘Save and Send Test Request’ in Pabbly Connect. This sends the mapped data to Keep and creates a new contact. Verify the contact has been created by checking your Keep dashboard.
To ensure the automation works, fill out the Landing G form again with new details. Each submission should trigger the creation of a new contact in Keep through Pabbly Connect. This confirms that your integration is functioning correctly.
In summary, we successfully set up an integration using Pabbly Connect to automate contact creation in Keep from Landing G form submissions. This process streamlines your workflow and saves time on manual data entry.
This tutorial demonstrated how to use Pabbly Connect to automate the creation of Keep contacts from Landing G form submissions. By following these steps, you can enhance your workflow efficiency and ensure that all potential leads are captured seamlessly.
