Learn how to seamlessly integrate JotForm with Kit using Pabbly Connect. This detailed tutorial walks you through each step of the automation process. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start integrating JotForm with Kit, access Pabbly Connect through your web browser. Simply search for Pabbly Connect and click on the official link to reach the landing page.
If you don’t have an account, click on the ‘Sign Up for Free’ button to create one. This process takes only a couple of minutes and provides you with 100 free tasks every month. If you’re already a user, click on the ‘Sign In’ button to log into your account.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you need to create a new workflow for the JotForm and Kit integration. Click on the ‘Create Workflow’ button to initiate this process.
- Name your workflow, for example, ‘Create Kit Subscriber on JotForm Submission’.
- Select a folder to save the workflow.
This is where you will set up the trigger and action for your workflow. The trigger will be the event that initiates the workflow, while the action will be what happens as a result of that trigger.
In this step, you will set up the trigger for your workflow using Pabbly Connect. Search for JotForm as the trigger application and select it.
Next, choose the trigger event as ‘New Response’. This event will activate whenever a new form submission is received. To connect JotForm with Pabbly Connect, you will need to use the provided Webhook URL.
- Copy the Webhook URL provided by Pabbly Connect.
- Go to your JotForm account and edit the form you want to connect.
- In the form settings, navigate to Integrations and select Webhooks.
- Paste the Webhook URL and complete the integration.
After completing these steps, your JotForm will send new submissions to Pabbly Connect automatically.
Now that your trigger is set up, it’s time to configure the action in Pabbly Connect. Search for Kit as the action application and select it.
Choose ‘Add Subscriber to a Sequence’ as your action event. To connect Kit with Pabbly Connect, you will need your API key and API secret from your Kit account. Log into Kit, navigate to the settings, and copy these details.
Paste the API key and API secret into Pabbly Connect. Select the sequence ID where you want to add the subscriber. Map the fields from JotForm submission to the respective fields in Kit.
Once all details are filled, click on ‘Save and Send Test Request’ to check if the integration is working correctly. You should receive a positive response indicating that the subscriber has been added.
5. Verifying the Integration Results
After completing the setup in Pabbly Connect, it’s crucial to verify if the integration works as intended. Go back to your Kit account and check the subscribers list.
Look for the new subscriber that was created from your JotForm submission. You should see all the details filled in correctly, confirming that the integration was successful. This automation will significantly streamline your subscriber management process.
With every new submission in JotForm, a new subscriber will automatically be added to your Kit account, ensuring you can engage with your audience without manual entry.
In this tutorial, we explored how to integrate JotForm with Kit using Pabbly Connect. By following these steps, you can automate the process of adding subscribers efficiently. This integration not only saves time but also enhances your email marketing efforts.
