Learn how to sync Instamojo sales to SendinBlue mailing list using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start the integration process, access Pabbly Connect and create a new workflow. This is where you will automate the syncing of sales data from Instamojo to SendinBlue. Begin by logging into your Pabbly Connect account and clicking on ‘Create Workflow’.
Once in the workflow setup, name your workflow appropriately, such as ‘Instamojo to SendinBlue Integration’. This helps in identifying the workflow later. After naming, select Instamojo as your trigger application to initiate the process.
2. Configuring Trigger in Instamojo
In this step, you will set up the trigger for your workflow using Pabbly Connect. Choose the event type that will trigger the integration, such as ‘New Sale’. This ensures that every time a sale is made on Instamojo, it will automatically trigger an action in SendinBlue.
  • Select ‘New Sale’ as the trigger event.
  • Connect your Instamojo account by providing the necessary API keys.
  • Test the connection to ensure it is working correctly.
After configuring the trigger, click on the ‘Save’ button. This will ensure that your workflow is ready to capture any new sales made on Instamojo.
3. Setting Up Action in SendinBlue
Next, you will configure the action step in your workflow using Pabbly Connect. Select SendinBlue as the action application. This step is crucial as it defines what happens when the trigger event occurs.
Choose the action event, such as ‘Add Contact’. This means that every new sale in Instamojo will add a new contact to your SendinBlue mailing list. Ensure that you map the fields correctly, such as email and name, to ensure data accuracy.
  • Select ‘Add Contact’ as the action event.
  • Map the fields from Instamojo to SendinBlue.
  • Test the action to verify it works as intended.
After mapping the fields, click on ‘Save’ to finalize this action step within Pabbly Connect. This ensures that all new sales data is accurately sent to SendinBlue.
4. Testing and Finalizing the Integration
Testing the integration is a vital step to ensure everything functions correctly. In Pabbly Connect, use the test feature to simulate a new sale in Instamojo. This will allow you to see if the data is properly sent to SendinBlue.
Once the test is complete, check your SendinBlue account to confirm that the new contact has been added. If everything looks good, you can proceed to activate your workflow. This ensures that the integration is live and will work automatically moving forward.
After activation, monitor the integration for a few sales to ensure that data is flowing smoothly between Instamojo and SendinBlue. With Pabbly Connect, you can easily manage and troubleshoot any issues that may arise.
5. Conclusion
Integrating Instamojo with SendinBlue using Pabbly Connect allows for seamless automation of your sales data. By following the steps outlined, you can efficiently sync sales information to your mailing list. This integration helps streamline your marketing efforts, ensuring that all new customers are engaged promptly.
Utilizing Pabbly Connect for this process enhances your business’s efficiency and effectiveness in managing customer relationships through automated workflows.
