Learn how to integrate Instamojo with Notion using Pabbly Connect for seamless automation of payment details. Follow our detailed tutorial for step-by-step instructions. Transform complex automation concepts into accessible, actionable steps that eliminate unnecessary manual work while maximizing existing application capabilities.
To start integrating Instamojo with Notion, you need to access Pabbly Connect. Simply visit the Pabbly Connect website by typing the URL in your browser. Once there, you will see options to sign in or sign up for free.
If you’re a new user, click on the ‘Sign up for free’ button to create your account. After signing up, you will receive 100 free tasks each month to explore the features of Pabbly Connect. If you already have an account, just click ‘Sign in’ to log in.
After logging into Pabbly Connect, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ option to start the process. A dialog box will prompt you to name your workflow; enter a descriptive name like ‘Add Successful Instamojo Payment Details to Notion’.
Next, select the appropriate folder for your workflow, such as ‘Automations for Learning Management’. Once everything is set, click on ‘Create’ to proceed. Now you will see two main sections: Trigger and Action, which are essential for setting up the automation.
- Name your workflow clearly for easy identification.
- Select a relevant folder to organize your workflows.
- Understand that Trigger initiates the workflow, while Action is the task performed.
Now that your workflow is created, you are ready to set up the Trigger and Action components that will connect Instamojo and Notion through Pabbly Connect.
Setting Up the Trigger with Instamojo
The next step is to set up the Trigger in Pabbly Connect. Select Instamojo as your trigger application and choose the event ‘New Sale’ to capture whenever a successful payment is made. This will allow you to automate the process of recording payment details.
After selecting the trigger, Pabbly Connect will provide you with a webhook URL. This URL must be added to your Instamojo account to establish the connection. Go to your Instamojo dashboard, locate the smart page for your product, and navigate to the page settings where you can paste the webhook URL into the ‘Webhook’ field.
- Select the page settings in Instamojo for your product.
- Paste the webhook URL provided by Pabbly Connect.
- Ensure to save the changes to activate the webhook.
Once saved, Pabbly Connect will start waiting for a response from Instamojo, indicating that the connection is successful.
Capturing Payment Details in Pabbly Connect
Now that the connection is established, it’s time to test the integration by making a payment through Instamojo. Navigate to your smart page and fill in the payment details. Once you complete the payment, Pabbly Connect will capture the payment details, including the student’s name, email, phone number, and transaction ID.
In the Pabbly Connect dashboard, you will see the captured response with all relevant details. This confirms that the integration is functioning properly. You can review the details captured to ensure they match the information entered during the payment process.
Verify that the payment status is marked as ‘Success’. Check that all customer details are accurately captured. Ensure the transaction ID is unique for each payment.
With these details captured, you are now ready to proceed to the next step of sending this information to Notion using Pabbly Connect.
Adding Payment Details to Notion
To complete the automation, you need to set up the Action in Pabbly Connect to send the captured payment details to Notion. Select Notion as your action application and choose the event ‘Create Database Item’. This will allow you to add the payment details to your Notion database.
After selecting the action event, you will need to connect your Notion account to Pabbly Connect. Once connected, select the database where you want to store the payment details, such as ‘PHP Programming Course Students Details’. Then, map the fields from the Instamojo response to the corresponding fields in your Notion database.
Map the first name, email, and phone number fields from Instamojo to Notion. Ensure that the transaction ID is also mapped correctly. Test the action to confirm that data is being sent to Notion as expected.
Once everything is set up, click on ‘Save and Send Test Request’ to finalize the process. You should see the new payment entry in your Notion database, confirming that the integration is successful.
This tutorial demonstrated how to seamlessly integrate Instamojo with Notion using Pabbly Connect. By automating the process of recording payment details, you can save time and enhance your workflow efficiency. With the steps outlined, you can easily set up this integration for your business needs.
Utilizing Pabbly Connect for such integrations allows for a more streamlined approach to managing your online transactions and records. Start automating your processes today for better productivity!
