Learn how to seamlessly integrate Instagram leads with System.io using Pabbly Connect. Follow our step-by-step guide for automation. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To integrate Instagram leads with System.io, you first need to access Pabbly Connect. Start by navigating to the Pabbly Connect website, where you have options to sign in or sign up for free. If you are a new user, you can sign up and receive 100 tasks for free every month.
Once signed in, you will be directed to the dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button located at the top right corner of the screen. This is where the integration process begins, utilizing the automation capabilities of Pabbly Connect.
2. Setting Up Trigger and Action in Pabbly Connect
In this section, you will set up the trigger and action for your integration using Pabbly Connect. The trigger application will be Instagram Lead Ads, and the action application will be System.io. Begin by naming your workflow appropriately, such as ‘Create System.io Contact from Instagram Ads Leads’.
- Select ‘Instagram Lead Ads’ as your trigger application.
- Choose the trigger event as ‘New Lead Instant’.
- Set ‘System.io’ as your action application with the action event as ‘Create a New Contact’.
Once you have selected your trigger and action applications, click on the ‘Connect’ button to establish the connection. This will allow Pabbly Connect to automate the process of capturing leads from Instagram and creating contacts in System.io.
3. Connecting Instagram Lead Ads to Pabbly Connect
To connect Instagram Lead Ads to Pabbly Connect, you need to authorize the connection through your Facebook account. Click on the ‘Connect with Instagram Lead Ads’ button and select your Facebook account. Ensure that your Instagram account is linked to this Facebook account.
After successful authorization, you will see a confirmation message. Now, you need to select the Facebook page that is associated with your Instagram account and the lead gen form you have created. This step is crucial as it allows Pabbly Connect to access your leads from Instagram.
4. Testing the Integration with a Sample Lead
To ensure that your integration works correctly, you should test it by generating a sample lead. You can use the Meta Lead Ads Testing Tool to create a test lead. Fill in the necessary details in the lead form and submit it to see if the lead is captured in Pabbly Connect.
- Navigate to the Meta for Developers page and access the lead ads testing tool.
- Select your Facebook page and lead form.
- Submit the form to generate a test lead.
Once the test lead is submitted, check Pabbly Connect to confirm that the lead details have been captured successfully. This ensures that your automation is functioning as intended.
5. Finalizing the Automation to Create a Contact in System.io
After confirming that the test lead has been captured in Pabbly Connect, proceed to create a contact in System.io using the lead details. You will need to establish a connection with System.io by providing an API key from your System.io account.
To do this, go to your System.io settings and create a new API key. Once you have copied the key, paste it into Pabbly Connect to complete the connection. After mapping the lead details to the respective fields in System.io, click on ‘Save and Send Test Request’ to finalize the process.
In this tutorial, we demonstrated how to integrate Instagram leads with System.io using Pabbly Connect. By following the step-by-step process, you can automate the creation of contacts from your Instagram ads, streamlining your lead management. This integration enhances efficiency and ensures that no lead is missed in your marketing efforts.
