Learn how to integrate Instagram Lead Ads with Riggy using Pabbly Connect for seamless user enrollment. Follow our detailed tutorial for a step-by-step process. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To start integrating Instagram Lead Ads with Riggy, you first need to access Pabbly Connect. Open your web browser and navigate to the Pabbly Connect landing page.
If you’re a new user, click on ‘Sign up for free’ to create an account. Existing users should click on ‘Sign in’ to access their dashboard. Once signed in, you can begin setting up your workflow for integration.
After accessing Pabbly Connect, create a new workflow to connect Instagram Lead Ads and Riggy. Click on the ‘Create Workflow’ button, name your workflow (e.g., ‘Enroll Riggy User from Instagram Lead Ads’), and save it in the desired folder.
  • Click on ‘Create’ to open the workflow window.
  • Select ‘Instagram Lead Ads’ as your trigger application.
  • Choose ‘New Lead Instant’ as the trigger event.
In this window, you will define the trigger and action for your automation. The trigger will initiate the workflow whenever a new lead is generated from your Instagram ads.
3. Connect Instagram Lead Ads to Pabbly Connect
To connect your Instagram Lead Ads with Pabbly Connect, click on ‘Connect’ after selecting your trigger event. You will need to authorize your Instagram account by clicking on the ‘Connect with Instagram Lead Ads’ button.
Follow the prompts to select your Facebook account linked to Instagram. Ensure you grant all necessary permissions for lead data access. Once authorized, select the specific Facebook page and lead generation form you wish to use.
4. Test Submission for Lead Capture
After setting up the connection, it’s essential to test the integration. Use the Meta for Developers tool to submit a test lead through your selected Instagram lead form. This will help capture the webhook response in Pabbly Connect.
  • Open the Meta for Developers page and navigate to the Lead Ads Debug tool.
  • Choose the Facebook page and lead form you set up earlier.
  • Fill in the required details and submit the form.
Once the test lead is submitted, return to Pabbly Connect to confirm that the lead data has been captured successfully. This step is crucial for ensuring that future leads will trigger the workflow as intended.
5. Enroll User in Riggy via Pabbly Connect
Now that the trigger is set up, it’s time to enroll the captured lead in Riggy. Select ‘Riggy’ as your action application in Pabbly Connect and choose ‘Import User’ as the action event.
Connect your Riggy account by adding the required API token from your Riggy dashboard. Map the fields from the lead response to the corresponding fields in the Riggy user enrollment form, ensuring that data flows seamlessly from Instagram Lead Ads to Riggy.
Finally, click ‘Save and Send Test Request’ to enroll the user. If successful, you will see a confirmation message in Pabbly Connect. You can now check your Riggy account to verify that the user was enrolled correctly.
In this tutorial, we demonstrated how to integrate Instagram Lead Ads with Riggy using Pabbly Connect. By following these steps, you can automate user enrollment and streamline your lead management process effectively.
