Learn how to automate the integration of Insta Mojo with UTeach using Pabbly Connect. This tutorial provides a detailed, step-by-step guide for seamless automation. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To begin the integration process, you must access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or creating a new account. If you are a new user, click on ‘Sign Up for Free’ to create your account, which provides you with 100 free tasks to explore the platform.
Once logged in, navigate to the dashboard where you can see all your workflows. Click on the ‘Create Workflow’ button in the top right corner. In the dialog box that appears, name your workflow, such as ‘Create Student in UTeach for Insta Mojo Sale’, and click ‘Create’. This sets up the foundation for your integration process.
2. Setting Insta Mojo as the Trigger in Pabbly Connect
In the newly created workflow, you need to set up the trigger by selecting Pabbly Connect and then choosing Insta Mojo as your trigger application. The trigger event will be ‘New Sale’, which will initiate the workflow whenever a new product is purchased.
  • Select ‘Insta Mojo’ as the trigger application.
  • Choose ‘New Sale’ as the trigger event.
  • Copy the provided Webhook URL to connect your Insta Mojo account.
Next, go to your Insta Mojo dashboard, select the product you want to integrate, and navigate to the advanced settings. Paste the copied Webhook URL into the designated field and save your changes. This allows Insta Mojo to send data to Pabbly Connect whenever a sale occurs.
3. Configuring UTeach as the Action in Pabbly Connect
After setting up the trigger, the next step is to configure UTeach as the action application in Pabbly Connect. Select UTeach and choose the action event ‘Find User’. This action will search for the user in UTeach based on the email received from the Insta Mojo sale.
To connect UTeach, you’ll need to enter your domain and API key. Access your UTeach account, navigate to the settings, and copy the required details. Paste these into Pabbly Connect to establish the connection.
  • Select ‘Find User’ as the action event.
  • Enter your UTeach domain and API key.
  • Map the user email from the previous step.
Once you save the action, Pabbly Connect will check if the user already exists in UTeach. If the user is found, the next step will be to enroll them in the course.
4. Enrolling Users in UTeach Through Pabbly Connect
Now that you have confirmed the user exists, you can proceed to enroll them in the desired course using Pabbly Connect. Add a new action step and select UTeach again, this time choosing ‘Add Student to Course’. This action will directly enroll the user in the course as soon as a sale is confirmed.
Map the necessary fields such as student email and course slug. The course slug can be found in the URL of the course page in UTeach. This ensures that the correct course is selected during the enrollment process.
Select ‘Add Student to Course’ as the action event. Map the student email from the previous step. Input the course slug for the desired course.
After saving this action, Pabbly Connect will handle the enrollment automatically, ensuring that all new users from Insta Mojo are added to the correct course in UTeach.
To finalize the integration, it’s crucial to test the entire workflow using Pabbly Connect. Make a dummy purchase from your Insta Mojo store to trigger the workflow. After completing the purchase, return to Pabbly Connect to verify that the data has been successfully received.
Check your UTeach account to confirm that the new student has been created and enrolled in the course. If everything is set up correctly, you should see the new user listed in your student section.
Complete a test purchase on Insta Mojo. Return to Pabbly Connect and check for the response. Verify the new student enrollment in UTeach.
If the student appears in UTeach, your integration is successful! Now, you can automate the process of enrolling students from Insta Mojo to UTeach seamlessly using Pabbly Connect.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Insta Mojo with UTeach for automatic student enrollment. By following these steps, you can streamline your enrollment process and enhance your educational offerings.
