Learn how to automate the creation of SendFox contacts from Insta Mojo sales using Pabbly Connect. Follow our detailed tutorial for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
To start automating your sales processes, you need to access Pabbly Connect. This integration platform allows you to connect various applications seamlessly. First, create a free account on Pabbly Connect, which takes only a few minutes.
Once you log in to Pabbly Connect, you will reach the dashboard. Here, you can create workflows to automate tasks between different applications. The first step is to click on the blue button labeled ‘Create Workflow’ to begin setting up your automation.
After clicking ‘Create Workflow’, you will be prompted to name your automation. For this integration, name it something like ‘Create SendFox Contact on Insta Mojo Sale Automatically’. Then, click ‘Create’.
- Select Insta Mojo as the trigger application.
- Choose the trigger event as ‘New Sale’.
- Pabbly Connect will provide a webhook URL for you to use.
Now, copy the webhook URL provided by Pabbly Connect and head over to your Insta Mojo dashboard. You will need to paste this URL in the advanced settings of the specific product you want to track sales for.
3. Configuring Insta Mojo for Webhook
To configure Insta Mojo, navigate to the products section and select the product for which you want to capture sales data. Click on the ‘Edit’ button and go to the ‘Advanced’ section.
Here, you will find an option to add a webhook URL. Delete any existing URL and paste the one you copied from Pabbly Connect. After saving, your Insta Mojo account will be connected to Pabbly Connect, enabling it to send data upon new sales.
Next, you need to test the integration. Make a test sale on your Insta Mojo product to ensure that the webhook triggers correctly. Input dummy details such as a name, email, and phone number during the checkout process.
- Complete the payment process.
- Return to Pabbly Connect to check for the webhook response.
- Verify that the customer details have been captured successfully.
Once you see the response with the correct data, it confirms that the connection between Insta Mojo and Pabbly Connect is working effectively.
5. Sending Data to SendFox via Pabbly Connect
Now that your Insta Mojo is set up, the next step is to send the captured customer data to SendFox. In Pabbly Connect, select SendFox as the action application and choose ‘Add Contact to List’ as the action event.
To connect SendFox, you will need to generate an API token from your SendFox account. After obtaining the token, paste it into Pabbly Connect to establish the connection. Now, you can map the customer details like first name, last name, and email from the previous step to the corresponding fields in SendFox.
After mapping the fields, click on ‘Save and Send Test Request’. Once confirmed, you can refresh your SendFox contact list to see the new contact added successfully. This integration allows for seamless data transfer every time a sale occurs, all managed by Pabbly Connect.
In this tutorial, we demonstrated how to integrate Insta Mojo with SendFox using Pabbly Connect. This powerful integration automates the process of creating contacts in SendFox whenever a sale occurs in Insta Mojo, saving you time and effort.
