Learn how to seamlessly integrate Gravity Forms with Go High Level using Pabbly Connect in this step-by-step tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start integrating Gravity Forms with Go High Level, you first need to access Pabbly Connect. This platform will enable you to automate the process of creating contacts based on form submissions automatically.
Open a new tab and search for Pabbly Connect. You will be directed to the landing page where you can either sign in or sign up for a free account. Signing up takes just a couple of minutes and provides you with 100 free tasks each month.
Once you are logged into Pabbly Connect, navigate to the dashboard. Here, you will create a new workflow to connect Gravity Forms and Go High Level. Click on the ‘Create Workflow’ button.
  • Name your workflow, such as ‘Create Go High Level Contact with Tags on Gravity Form Submission’.
  • Select the folder where you want to save your workflow.
This will take you to the workflow window where you can set up your trigger and action. The trigger will be Gravity Forms, while the action will be Go High Level.
3. Setting Up Trigger with Gravity Forms
In your new workflow, the first step is setting up the trigger. Select Gravity Forms as your trigger application in Pabbly Connect. Next, choose the trigger event as ‘New Response’.
You will need to connect Gravity Forms with Pabbly Connect using a webhook URL. This URL acts as a bridge between both applications. Copy the webhook URL provided by Pabbly Connect and proceed to your Gravity Forms account.
4. Configuring Gravity Forms to Use the Webhook
In Gravity Forms, you need to activate the Webhooks add-on. Navigate to the Add-ons section, find the Webhooks add-on, and activate it. After activation, go to the forms section and select the form you wish to integrate.
  • Open the settings of your selected form.
  • In the settings, find the Webhooks option and click on it.
  • Click on the ‘Add New’ button to create a new webhook.
  • Paste the copied webhook URL and set the request method to POST with JSON format.
Save your settings, and now your Gravity Forms are ready to send data to Pabbly Connect.
5. Setting Up the Action in Pabbly Connect
Now that your trigger is set up, it’s time to configure the action. In Pabbly Connect, select ‘Lead Connector V2’ as your action application. Choose ‘Create Contact’ as the action event.
Connect your Go High Level account by clicking on ‘Add New Connection’. Fill in the required details and ensure the connection is successful. Next, map the fields from your Gravity Forms submission to the corresponding fields in Go High Level.
For example, map the first name, last name, email, and any tags you want to assign to the new contact. Once all details are mapped, click on ‘Save and Send Test’. This will confirm that the integration is working as expected.
In this tutorial, we explored how to use Pabbly Connect to integrate Gravity Forms with Go High Level effectively. By following these steps, you can automate the process of creating contacts based on form submissions, streamlining your workflow and improving efficiency.
