Learn how to automate sending Zoho Click messages for new Google Ads leads using Pabbly Connect. Step-by-step tutorial with detailed instructions. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start integrating Google Ads and Zoho Click, first, access Pabbly Connect. Simply type Pabbly.com/connect in your browser. After reaching the landing page, you will need to sign in or sign up for free.
If you’re an existing user, click on the ‘Sign In’ button. New users can create an account to receive 100 free tasks monthly. Once signed in, you will see your dashboard, which includes all your workflows and folders.
Next, create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button. You will be prompted to enter a workflow name and select a folder to save it. For this integration, name it ‘Send Zoho Click Channel Message for New Google Ads Leads’.
  • Click on the ‘Create’ button after entering the name.
  • You will see two boxes labeled ‘Trigger’ and ‘Action’.
In this workflow, the trigger application will be Google Ads, and the action application will be Zoho Click. This means every time a new lead is generated in Google Ads, a message will automatically be sent to Zoho Click.
3. Setting Up Google Ads as Trigger in Pabbly Connect
To set Google Ads as the trigger in Pabbly Connect, select it as your trigger application and choose ‘New Lead Form Entry’ as the trigger event. This action will initiate the workflow whenever a new lead is submitted.
After selecting Google Ads, Pabbly Connect will provide a webhook URL. Copy this URL as it will be used to connect Google Ads with Pabbly Connect. Now, navigate to your Google Ads account to set up the webhook.
  • Open the lead form you created in Google Ads.
  • In the lead delivery option, paste the webhook URL provided by Pabbly Connect.
After pasting the URL, enter a key (like ‘testing’) and click on ‘Send Test Data’ to verify the connection. If successful, you will see the test data reflected in your Pabbly Connect dashboard.
4. Configuring Zoho Click as Action in Pabbly Connect
Now, it’s time to set Zoho Click as the action application in Pabbly Connect. Choose ‘Send Message to Channel’ as the action event. Click on ‘Connect’ to establish a connection with Zoho Click.
If you don’t have an existing connection, select ‘Add New Connection’. Enter your Zoho Click domain, which can be found in your Zoho Click account. After entering the domain, click on ‘Save’ and authorize the connection.
Select the channel where you want to send the message, for example, ‘Google Leads’. Draft your message using dynamic fields from the Google Ads lead.
Utilize mapping to insert lead details like first name, last name, email, and city into your message. This ensures that every new lead’s information is automatically included in the message sent to Zoho Click.
5. Testing the Integration between Google Ads and Zoho Click
After configuring both trigger and action applications in Pabbly Connect, it’s essential to test the integration. Click on ‘Save and Send Test Request’ to send a test message to your selected Zoho Click channel.
Check your Zoho Click account to confirm that the message was received. The message should include the dynamic details from the Google Ads lead, confirming that the integration works as intended.
Ensure that the message format is correct and all lead details are accurately displayed. If everything looks good, your automation is successfully set up!
This integration allows you to automate your lead management process efficiently, ensuring timely follow-ups with potential clients.
In this tutorial, we demonstrated how to integrate Google Ads and Zoho Click using Pabbly Connect. By following the steps outlined, you can automate your lead notifications, ensuring no lead goes unattended. This setup enhances your workflow and improves client engagement.
