Learn how to integrate Go High Level and AWeber using Pabbly Connect to automate subscriber updates seamlessly. Follow this detailed tutorial for step-by-step instructions. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To integrate Go High Level and AWeber, start by accessing Pabbly Connect. You can reach the Pabbly Connect homepage by typing ‘Pabbly.com/connect’ in your browser. If you’re a new user, click on ‘Sign Up for Free’ to create an account and explore its features.
Once logged in, you will see the dashboard where you can find all your workflows. To create a new workflow, click on the ‘Create Workflow’ button. This is where you will set up the automation between Go High Level and AWeber using Pabbly Connect.
Creating a workflow in Pabbly Connect involves naming your workflow and selecting the appropriate folder for organization. For this integration, name your workflow ‘Update AWeber Subscriber with Tag for Go High Level Appointment’.
  • Click on the ‘Create’ button after naming your workflow.
  • Select ‘Go High Level’ as the trigger application.
  • Choose ‘Customer Booked Appointment’ as the trigger event.
By setting this up, you define that whenever a new appointment is booked in Go High Level, the workflow will trigger and execute the action in AWeber through Pabbly Connect.
3. Connecting Go High Level with Pabbly Connect
To connect Go High Level with Pabbly Connect, you will use the Lead Connector V2. After selecting it as your trigger, you will be provided with a webhook URL. This URL is essential for linking Go High Level to Pabbly Connect.
Copy the webhook URL and head over to your Go High Level account. Navigate to the ‘Automations’ section and create a new workflow. Set the trigger as ‘Customer Booked Appointment’ and paste the copied webhook URL into the action settings. This will ensure that every time an appointment is booked, the data is sent to Pabbly Connect.
4. Setting Up AWeber Action in Pabbly Connect
After successfully connecting Go High Level, the next step is to set up the action in AWeber. You will select AWeber as your action application in Pabbly Connect and choose ‘Add or Update Subscriber’ as the action event.
Connect to your AWeber account by clicking ‘Connect Now’. Once connected, you will need to map the data from the Go High Level response to the corresponding fields in AWeber. This includes mapping the subscriber’s full name, email, and phone number.
  • Select the list ID for the subscribers in AWeber.
  • Choose the tags you want to assign to the subscriber, like ‘Go High Level Appointment’.
This mapping process is crucial as it ensures that every new appointment booking updates the correct subscriber in AWeber through Pabbly Connect.
Once everything is set up, it’s time to test your integration. Go back to Go High Level and book a sample appointment. Fill in the required details and schedule the meeting. This action should trigger the workflow in Pabbly Connect.
After scheduling, check your AWeber account to see if the subscriber has been updated with the specified tag. If everything is configured correctly, you should see the subscriber tagged as expected.
By following these steps, you can successfully automate the process of updating AWeber subscribers whenever a booking is made in Go High Level using Pabbly Connect. This integration saves time and ensures that your subscriber list is always up to date.
This tutorial demonstrated how to integrate Go High Level and AWeber using Pabbly Connect to automate subscriber updates. By following the steps outlined, you can streamline your workflow and enhance efficiency in managing appointments and subscribers.
